Trick's NEW Twin Turbo kit. GP FREE FREIGHT
#24
Twin turbo kit
Trick is now offering a new Twin Turbo Kit for GM trucks.
This kit has been in the design stage for some time. We know the customers want a quality kit that looks good, fits good, and can give big hp numbers. This kit fits the bill.
We started off using the 52/52, but those units are no longer available. So going to a larger 61/52 bumps the upper HP rating even higher. The precision waste gates come with a good amount of springs, from 1.3-25.7psi. Gates are vented back into the down pipes. Nice and quiet.
The turbo's locations give a clean look while staying symmetrical. The turbo log manifolds will not crack under the weight of the turbos and keeps the over all package down low in the engine bay.
Kit comes with
2) Precision 61/52 t3 turbo 640hp rating per turbo
2) Precision 39mm waste gates. Vented back into the down pipes.
2) down pipe flex joints adapters to gates.
2) swept runner thick wall steel manifolds
2) 3" stainless steel down pipes. down pipes stop under the floor pan.
2) O2 bungs welded into down pipes
2) Turbo blankets
2) Hi Flow Air filters with 90' silicone boots
2) oil drain line kits
*) 50mm BOV
*) oil psi line that T's to the turbos
*) Heater hose and clamps
*) Vacuum hose for all gates and blow off valve
*) 1 roll of header wrap must be applied
*) 1 3ft thermal sleeve to cover ac line or other lines near heat
*) Heat shield for brake booster and master cylinder area
*) cold pipes with bead rolled ends.
*) Black silicone couplers and Stainless Steel t-bolt clamps
*)T-body cold pipe will have 2 meth bungs, 1 IAT bung welded in
*) 3/8npt drill and tap
*) mounting bracket/support for inter cooler core.
*) custom build air to water OR air to air inter cooler
Air/water core mounts in the engine bay between the fans and the water pump and rests on the top side of the frame rails. Stock fans may not work and air/air maybe a better option for your application.
Air/Air inter cooler core is a grill mounted core. Will clear the frame rails and may only need minor bumper bracket modding on some models.
* air to water kits do not come with pump, hoses or tank. Seeing how each person has a different location, they might want to mount these items differently. They are left out.
Air/Water and Air/Air Kits retail price is $6900.00
A group buy of 3 or more kits would be
$6700.00 and free freight !!!.
Pics show the major parts. Several smaller parts are left off the pics.
First pic shows air/water build.
Air/water core pics.
Things that need to be moved:
Battery relocation is needed from the front driver side to the auxiliary location or rear of the truck. Minor brake line movement is need to clear the drivers down pipe. I would thermal sleeve these as well.
Wires on the drivers side. We recommend re-routing away from heat source. Let's face it, there are a lot of wires over on the drivers side right where the turbo, down pipe, and gate vent are. So great care must be taken in this area to keep the wires from melting.
Kit comes with
2) Turbo blankets
*) 50mm BOV
Saif
#28
GXPJAY
02-13-2022 08:15 AM
5.3lSilverado
25
08-29-2016 12:48 AM
03regcab sierra
20
08-03-2015 12:11 AM
lxcoupe
07-21-2015 02:12 AM
