NEW from B&M: GM TH350 and 700R4 Transmission Packages
Available: January 1, 2017
Part #107105
Description:
B&M’s TH350 Holeshot 2000 transmission package is a convenient way to make sure you have everything needed to install your new transmission. This package includes the transmission, a 2000 stall Holeshot converter, kickdown cable, dipstick, medium SuperCooler, and 3 gallons of Trick Shift Fluid. The transmission has a 6 inch tailshaft and 7 inch separation on the top bellhousing bolts.
• Rated up to 450 HP and 400 lb-ft Torque
• For 2 Wheel Drive Applications
• 6 Inch Tailshaft
• For Street and Strip Use
Part #107106
Description:
B&M’s GM 700R4 Holeshot 2400 transmission package is a convenient way to make sure you have everything needed to install your new transmission. This package includes the transmission, a 2400 stall Holeshot converter, kickdown cable, dipstick, large SuperCooler, and 3 gallons of Trick Shift Fluid. The transmission does not replace the 4L60E.
• Rated up to 500 HP and 450 lb-ft Torque
• 30 Tooth Spline Converter
• Not for Corvette and 60 Degree Angled V6 Models
Please call 707-544-4761 or visit www.bmracing.com for additional application and product information.
Part #107105
Description:
• 6 Inch Tailshaft
Part #107106
Description:
