B&M Trick Shift Fluid - 1 Gallon Containers
B&M Part #80260
Trick Shift Fluid – 1 Gallon Container
Trick Shift was originally developed by B&M for racing applications. It’s become so successful that it’s the most popular high performance fluid on the street also! Not an additive, this is the best performance ATF available! A scientific blend of foam inhibitors, pressure agents and shift modifiers that will provide extended transmission life and drastically improve shift feel. Trick Shift is the easiest way to measurably improve the transmission performance of your vehicle. Trick Shift works with all automatic transmissions when a firmer shift is desired. Pour in Performance is not just a catchy phrase - it’s reality! It can be mixed with stock-type transmission fluids, however, to attain maximum improvement you should use Trick Shift exclusively. Ideal for towing, light trucks and RV applications, as well as racing. Not recommended for electronic controlled transmissions.
Please call 707-544-4761 or visit www.bmracing.com for additional application and product information.
• Desirable Firmer Shift
• Ideal For Performance Street
• Ideal For Racing
• Not An Additive
B&M part #80260
• Ideal For Racing
• Not An Additive
B&M part #80260
Have you poured in the performance with Trick Shift Automatic Transmission Fluid? Join Steve as he explains why you should add Trick Shift to the automatic transmission in your vehicle.
B&M Racing
06-09-2016 01:49 PM
