B&M TH700R4/4L60 Street/Strip and Traveler Series Transmissions
Available March 1st, 2017
B&M TH700R4/4L60 Street/Strip and Traveler Series Transmissions (parts 107101, 107104, and 117103)
Application: 84-92 2WD (part 107101) or 4WD (part 107104) GM 700R4/4L60 non-electronic with 30 Spline Input
Description:
Traveler Transmissions are rugged models that have a medium firm shift compared to the
harder shift of the Street Strip models. The Traveler transmissions are recommended for
light trucks, RV, Towing and off-road applications for heavy duty use and feature an increase
of oil flow compared to a stock transmission. This increased oil flow provides the necessary
additional cooling to make these transmissions live longer when subjected to mile after mile
of grueling abuse. B&M strongly recommends adding a Hi-Tek trans cooler to help further
reduce heat build-up and extend the life of all automatic transmissions. Does not fit Corvette,
or 60 degree V6 engines. Does not replace 4L60E transmissions.
Please call 707-544-4761 or visit www.BMRacing.com for additional application and product
information.
• Heavy Duty RV, Towing and Off-Road
• Medium Firm Shifts
• Increased Internal Cooling Capacity
• Rated to 500HP and 450LB FT
Street/Strip Transmission (part 117103)
Application: 84-92 2WD GM 700R4/4L60 (non-eletronic) with electric speedo
Description:
The B&M 700R4/4L60 Street Strip transmission is suitable for use behind engines
producing up to 500HP and 450LB FT of torque which covers most small block and mild
big block engines. It features a low first gear ratio and an overdrive 4th gear making it a
very desirable transmission for street strip applications. This 4L60 transmission is for the
electronic speedometer, but is not an electronically controlled transmission. B&M strongly
recommends adding a Hi-Tek trans cooler to help further reduce heat build-up and extend
the life of automatic transmissions. Can be used with a B&M Lock-up Controller. Does not fit
Corvette or 60 degree V6 engines. Does not replace 4L60E transmissions.
information.
• Street/Strip Transmission
• Heavy Duty Sunshell
• Electronic Speedo Connection
