B&M Hi-Tek Cast Deep Trans Pan for 2009-17 Toyota Tundra and Sequoia
Application:
2009-2018 Toyota Tundra and Sequoia with AB60 Transmission
Description:
B&M Hi-Tek Cast Aluminum Deep Transmission Pans are constructed of thick A356.0-T6 cast aluminum. Designed to fit Tundra and Sequoia models with the AB60 transmission, these anodized black deep pans significantly increase fluid capacity and dissipate heat much faster than factory units. This helps to prolong the life of the transmission and related components. Additional features include an engraved B&M logo, drain port, temperature sensor fitting, magnetic drain plug, as well as complete hardware and installation instructions. This Hi-Tek Deep Trans Pan is backed by B&M’s Lifetime Limited Warranty.
Please call 707-544-4761 or visit http://www.bmracing.com/ for additional application and product information.
• A356 Aluminum Construction
• Black Anodized Finish
• Additional Fluid Capacity
• Fill Plug and Magnetic Drain
• Easy Servicing
We are thrilled to announce that we have confirmed that the existing AB60 Cast Aluminum Trans Pan for the 2009+ Tundra will continue fitment through the 2018 model year for the same sub-model configurations as previously listed.
