B&M Deep Transmission Pan Overview
Features:
Excessive heat can kill a transmission quickly. And one of the best and easiest ways to help dissipate that excess heat from a transmission is by installing a B&M cast aluminum deep pan. The extra fluid capacity, multiple cooling fins, and greater heat transfer of aluminum all combine to make the B&M cast aluminum transmission pan a functional solution to keep your transmission running cool. Whether youre racing, towing, off-roading, or just an enthusiastic driver in warmer weather keeping your transmission cool is essential to its continued operation and longevity. In addition, this easy to install pan includes a drain plug to make fluid changes simple and less messy and all necessary hardware.
Multiple cooling fins for greater heat dissipation
Thick durable cast aluminum construction
CNC machined mounting surface, bolts holes, and ports
No modifications to dipstick required
Includes drain plug, temperature sensor ports, and all necessary mounting hardware
Easy installation with easy-to-follow instructions
Full warranty
For assistance selecting the correct part for your application, please contact our Sales Department at 707-544-4761.
Win a B&M Trans Pan!
This month, we are giving away a transmission pan on our website, www.bmracing.com. Click HERE to enter.
Rompn
02-18-2016 10:51 PM
