On 3 Performance New Truck Turbo System and Build
I have has zero issues with cooling, I run a fairly large overflow still in the truck. It still gets up into the 100's here as well and its not been an issue. My fans are on just a manual temp switch where I can control where they com on. Overheating is not going to be an issue at all
What does the intake for the turbo look like, where does it run to? Have you got around to making that and it is included in the kit? Also, what about the driver side manifold, I saw where you were going to try and make a tubular manifold, did you get that finished and would it be included in the kit?
I really like the looks of this kit under the hood. I guess my big complaint all along on front mounts is all the hot stuff under the hood and it being so cramped and so hard to get to everything on the passenger side. Your kit does not appear to be cramped at all and there is no denying the excellent pricing! May be selling my rear mount kit after all.
Ive designed 19 different production turbo systems and out of all, this is by far the most simple to install and work on. I like this platform a lot due to having so much room. I was able to lay everything out exactly how I wanted and allowed for a clean installed finish product
Also people with 07+ trucks, I have looked at an 08 and my friend 2010, I believe our system is going to be a direct bolt on as well for those years. Don't hold me to it at this point till its tested but visually, I think its going to fit the 07+ no problem
