SPONSOR PROJECTS, BUILDS, & CUSTOMERS TRUCKS Sponsor's have their own projects and customer's cars they'd like to show off too! Check them out here!
On 3 Performance New Truck Turbo System and Build
Old 12-21-2016, 01:40 PM
  #161
N/ALS1's Avatar
Originally Posted by slvrram
Followup to this post i made a couple days ago...
For those that have purchased this kit and own a pre 03 NBS silverado, the cold side IS NOT bolt on. With the earlier trucks, the bumper mounts curl over the frame horns on both sides preventing proper clearance for the 3" charge pipe to tie into the intercooler. The way they have it mounted in their pictures on their demo truck will not work with the older NBS Silverados. The only solutions that I could come up with were to mount the intercooler almost level with the lower frame rails up inside the bumper or flip the intercooler and run the charge pipes through the headlight area. I chose to do the later of the two as my truck is lowered and i don't need another ground clearance issue. Plus this would leave the IC far from direct airflow of the radiator fans. One large thing to note with this way is tons of grinding and hacking of the grill and headlight support frame are required. It can be done though.
With any luck, ON3 will make note and give heads up in their instructions.
Do you have any pics?
Old 01-01-2017, 06:11 PM
  #162
Daniel-lsx's Avatar
I purchased this kit for the Nnbs any one know what I can do to fit it correctly? Or any problems I would have ?
Old 01-02-2017, 12:51 AM
  #163
WICK3DxGATA's Avatar
mine fit with no problems
Old 01-22-2017, 09:56 PM
  #164
slvrram's Avatar
Which part? The bumper or what? PM me with your email if you are serious. I'll snap some more if needed.
Old 02-04-2017, 08:51 PM
  #165
N/ALS1's Avatar
PM sent
Old 08-20-2017, 10:55 AM
  #166
speedracer2536's Avatar
anyone put one on a 14+ yet
xxch0dyxx
02-03-2017 04:57 AM
LPCWS6
03-21-2014 08:49 PM
Sinr98
02-26-2014 03:09 PM
Jeff12
08-02-2007 09:22 PM
GoldenVelvet
03-24-2003 12:34 AM
Quick Reply: On 3 Performance New Truck Turbo System and Build
