SPONSOR PROJECTS, BUILDS, & CUSTOMERS TRUCKS Sponsor's have their own projects and customer's cars they'd like to show off too! Check them out here!
On 3 Performance New Truck Turbo System and Build
Old 03-26-2015, 05:19 PM
  #151
FFDP's Avatar
Just the kit itself with nothing else and you'd need a fuel pump, injectors, map sensor, figure out passenger side plug wires, heat wrap and other smaller odds and ends.
Some people upgrade the wastegate right off the bat too.
Old 03-26-2015, 08:52 PM
  #152
5speedsilverado's Avatar
ok cool, and all that stuff is listed in the option list good to use? its a daily driver, would the 76mm spool quick enough with my crew cab and 3.23 gears?
Old 04-05-2015, 05:32 PM
  #153
08lambochevy's Avatar
So far they sent me injectors that they said were same as sema deka 55's but are actually FoMoCo 42's and pigtails that dnt fit cuz there for an Fbody camaro and there wasgate is spiking 18#'s and its brand new.
Ever since i left them a voicemail about the injectors and pig tails they wont answer or call back
Old 05-05-2015, 07:46 PM
  #154
10 Second Club
^ That's not good, hope you can get it resolved.
Old 12-31-2015, 01:42 PM
  #155
Registered User
Dquist1's Avatar
Do you have any pictures of the driver side exhaust system and how it meets with the turbo. Is it ran cross the front are the back?
Old 01-05-2016, 02:11 PM
  #156
Pics on first page show the pipe crossing the back right below the transmission bell housing.
I would seriously look at saving up for a Trick system or KBRacing.
Old 02-18-2016, 11:56 PM
  #157
EXsoccer1921's Avatar
On your Ebay page it has an 88mm journal bearing turbo upgrade for $499. Do you have any installed pictures of this particular setup?
Old 06-09-2016, 11:53 AM
  #158
NoorJ's Avatar
Way off topic, but did you used to own a cobalt? I remember someone with an oddly similar name on that forum
Old 07-01-2016, 07:57 PM
  #159
slvrram's Avatar
Originally Posted by mike.w
I have the On3performance kit now. I have a 99 x-cab silverado. How do you get the intercooler to sit so low behind the bumper. The intercooler in the kit hits my bumper mounts for the frame. Any more pics of install or ideas? Overall, very impressed with the looks and weld of the kit.
I'm having the same problem as this guy. 2002 year model. Any updates?
Old 07-06-2016, 11:08 AM
  #160
slvrram's Avatar
Followup to this post i made a couple days ago...
For those that have purchased this kit and own a pre 03 NBS silverado, the cold side IS NOT bolt on. With the earlier trucks, the bumper mounts curl over the frame horns on both sides preventing proper clearance for the 3" charge pipe to tie into the intercooler. The way they have it mounted in their pictures on their demo truck will not work with the older NBS Silverados. The only solutions that I could come up with were to mount the intercooler almost level with the lower frame rails up inside the bumper or flip the intercooler and run the charge pipes through the headlight area. I chose to do the later of the two as my truck is lowered and i don't need another ground clearance issue. Plus this would leave the IC far from direct airflow of the radiator fans. One large thing to note with this way is tons of grinding and hacking of the grill and headlight support frame are required. It can be done though.
With any luck, ON3 will make note and give heads up in their instructions.
Quick Reply: On 3 Performance New Truck Turbo System and Build
