SPONSOR PROJECTS, BUILDS, & CUSTOMERS TRUCKS Sponsor's have their own projects and customer's cars they'd like to show off too! Check them out here!
2016 Project F150 Ecoboost by CARiD team
Old 03-03-2017, 09:44 AM
Former Vendor
carid's Avatar
How's it going everyone, a quick update on topic. While the Lift Kit installation video shows the whole process in the smallest details, we decided to compose a written summary of our experiences that would give you a couple of more useful tips and show what else should be taken care of to perform the installation properly.
Click on the picture below to read more at CARiD
Got questions? Post them up in the comments below and we will gladly respond!
Old 03-06-2017, 10:31 AM
Former Vendor
carid's Avatar
Since we're done with the installation of performance bolt-ons on our F150 project truck we decided that it's time to take care about the stopping power and install a set of Drilled and Slotted brake rotors by StopTech. It's a perfect upgrade in case you would like to bring the performance of your truck to the new level or simply perform a scheduled brake replacement. Plus, if you decide to tow with your rig, more stopping power will never hurt!
Effective heat dissipation is the main benefit of drilled and slotted rotors. Drilled holes and vanes allow water and gases to disappear and help to cool down the brakes more efficiently, which is exactly what we need for our Project F150!
Watch Greg from CARiD.com show you the step by step process of how easy is it to get brake rotors installed. These StopTech rotors are the perfect addition to any vehicle and can be installed in your home garage with basic hand tools.
Watch our new video below and let us know what do you think in the comments below!
Don't forget to hit the button Subscribe to stay up to date with our latest video reviews!
Link to the product:
StopTech® - Sport Drilled and Slotted Vented 1-Piece Brake Rotor
Find more tips and tricks on how to choose performance brake components for your truck in our new tech article:
How To Select And Install Performance Brake Rotors
Performance brakes are available for all other Ford Trucks as well.
Look them up here: https://www.carid.com/brakes.html
Read more about StopTech at CARiD.
Old 03-28-2017, 06:20 AM
Former Vendor
carid's Avatar
Hi everyone, today we would like to talk about the safety of the lift kits, because this important element is often being overlooked.
As you know lift kits change geometry of the suspension which is reflected in how your truck handles and behaves on the road. It also means that not all lift kits are equal in terms of safety and handling characteristics, because the center of masses is raised. Not all of the lift kit manufacturers would tell you if their lift solution will maintain normal suspension operation, but for our project truck we decided to pick one that would be reliable and absolutely safe to use. Pro Comp Stage1 6" lift kit happens to be one of such kits and unlike many other brands Pro Comp actually tests their kits and makes sure they correspond with current safety standard FMVSS 126.
Their kit for 2015&UP F150 received certification that it meets Federal Motor Vehicle Safety Standard 126 (FMVSS 126). FMVSS 126 requires the successful operation of electronic stability control (ESC) on all new vehicles under 10,000 pounds GVW. In order to demonstrate that Pro Comp’s suspension system did not negatively affect these systems on the new Ford pickup, Pro Comp had tests performed on an F-150 outfitted with their 6” Stage I suspension, 35-inch Pro Comp Xtreme MT/2 tires mounted on 20-inch Phantom Pro Comp Alloy wheels
Check more about Pro Comp lift kit safety test in this video:
Link to the kit: Pro Comp® - 6" Stage 1 Front and Rear Complete Lift Kit at CARiD
Old 04-28-2017, 07:19 AM
Former Vendor
carid's Avatar
How's it going everyone! Today we're here with another video in which we'll take a closer look at the wheels and tires on our truck. Even though the design of rims is quite a controversial topic, and it may never be everyone's cup of tea, we can confidently say that our F150 looks just right with this rims & tires combo and a 6 inch lift.
The rims are quite special because it's the very first off-road wheel designed by Asanti. This brand is famous for their high end wheels for premium sedans, sport cars and exotics. The AB811 wheel turned out to be really good looking and it comes in 3 sizes: 20x9", 20x12" and 22x12". For our truck we selected the top of the line 22x12" size and wrapped it with good old 35" Toyo Open Country tires. The coolest feature of these rims is the removable inserts in the wheel spokes. You can easily custom paint them or even wrap to personalize the design of the wheels if you want to.
More details about the wheels on our truck in the new video review from CARiD!
Asanti Off-road AB811 rims at CARiD
Check the full selection of Asanti Off-road rims here!
Let us know what do you think about the wheel setup on our truck!
Old 05-15-2017, 03:42 AM
Former Vendor
carid's Avatar
In order to complete the work in the wheels and tires department of our project truck we decided to cover the factory brakes with a set of aftermarket caliper covers. With the installation of large wheels, the calipers became exposed and clearly visible through the spokes, which doesn't always look good especially with dirt that builds up on them after taking the truck for a spin on a country road, so we picked the caliper covers to hide it and improve the cosmetics at the same time. Beside that, caliper covers give you that big brake look that we all love. It's not always necessary to invest much money in performance brakes if you are not gong to race the truck, so MGP caliper covers is a good solution for any project like this.
Watch how to install them on your truck in our next episode:
Link to the product: https://www.carid.com/ford-f-150-caliper-covers/
What do you think about this mod, and what else would you like us to install on this project truck?
Old 06-02-2017, 07:44 AM
Former Vendor
carid's Avatar
Those of you who follow our build thread probably remember, that in our first post we've mentioned Recon Headlights. Looks like we were waiting for the perfect ones and their time has come! We chose brand new Black/Smoke "Mustang Tri-Bar" Style Projector LED Headlights, available for Ford F-150 2015 & up. These lights feature a sleek U-Bar design that provides any truck with a unique style. Engineered with your needs in mind, they offer unrivaled visibility and reliability providing many years of hassle-free service. Plug-n-play design makes the installation process a breeze.
Link to the product: https://www.carid.com/2015-ford-f-15...287475868.html
What do you think about this upgrade?
Old 06-15-2017, 05:36 AM
Former Vendor
carid's Avatar
It took a while to find the right headlights for our truck, but it looks like this time we picked the coolest lights available on the market. They are made by Recon, one of the leaders in the automotive lighting industry. These Black/Smoke "Mustang Tri-Bar" Style Projector LED Headlights, look absolutely stunning when installed and will certainly turn heads when seen on the road. But we've chose them not only for the look as the quality of these lights is on a whole new level.
You can watch the whole installation process in our new episode:
Now Ford F-150 that we are building looks almost complete. What upgrade should we do next?
Old 06-15-2017, 06:08 AM
Former Vendor
carid's Avatar
Since we've already started to work on the exterior of our Ford, we've decided to go further and upgrade it with a set of awesome side steps. Nothing says off-road truck like a set of rock sliders on it, so we've choose one of the best examples of aggressive looking rock sliders on today's market – M1 Series Sliders from Smittybilt. They're crafted from durable steel into a 1.75" tubing, strong enough to fend off damage to the vulnerable rocker panels on your truck. Each step comes with a matte black textured powdercoat finish for maximum protection. The wheel to wheel design features dimpled steps and dual purpose rear slider flare in front of the bed, so you get easier stepping and access to your cab.
Easy to install with no drilling required, these sliders are designed for hassle free installation and rugged looks. As a result, Smittybilt sliders turn our Ford truck into the ultimate off-road getaway machine.
Link to the product: https://www.carid.com/smittybilt/m-1...s-sliders.html
Find out more about these steps in the next episode of our F150 build project:
Old 06-29-2017, 06:35 AM
Former Vendor
carid's Avatar
Today we are here with the next step for upgrading our Ford F-150 and we feel super excited about it. No other accessory will provide your truck with a tough, off-road style and an extra layer of defense between your truck and the trails better then an off-road bumper. We've searched for a long time and came up with another solid choice – Warn Ascent Full Width Front HD Winch Bumper. What do you think of when you hear Warn? Right, winches and toughness. Those 2 things are successfully combined in this bumper, along with refined, low-profile styling and ultra-durable 11-gauge steel construction.
It comes fully packed with utility features for both winches and lighting - this heavy-duty off-road front bumper accepts most WARN mid-frame winches up to 12,000 pounds and features integrated dual light ports to mount auxiliary flood or spot sights. This bumpers comes in a durable black textured powder coat, delivering up to 2X corrosion protection and also accommodates oversized wheels. The installation is a breeze - pre-drilled bolt holes and cutouts make it easy to mount a WARN winch, even after bumper install.
Watch our next episode to find out more:
Link to the product: https://www.carid.com/warn/ascent-fu...ch-bumper.html
With Warn Ascent Bumper installed on your truck you open up a world of possibilities for all your off-road adventures – you get the look you want, the rugged functionality you need and the highest level of protection. Now our Ford F-150 looks almost complete and ready to go for the next upgrade!
Old 10-26-2017, 11:28 AM
Former Vendor
carid's Avatar
Hey Guys,
We keep moving forward with our F-150 build and today we're going to install a sport bar on it to achieve better visibility and more badass look. Our product expert Greg has prepared an in-depth review of this awesome product. Watch the video below to find out more about it!
https://www.youtube.com/watch?v=Odr_...ature=youtu.be
Features:
* Lights not included;
* Removable side plates;
* Available in Textured Black and classic Polished stainless steel finish;
* Drilling is required.
* Mounts to truck bed rails;
* Go Rhino Sport Bar 2.0 can be used in conjunction with most bed covers;
* Power-actuated light mount so lights can be hidden away when not in use;
Link to the product: https://www.carid.com/go-rhino/sport...-bed-bars.html
What do you think about this Sport Bar? Would you install it on your F150?
