Props to Livernois!
I know a few people running thicker HG's in turbo diesel applications, which see way more cylinder pressures than the average gasoline engine. So, to me, it's the simplest option, plus it allows you to install headstuds or new head bolts, rework the valvetrain and/or a variety of maintenance things to ensure long-term reliability.
$500 to have the chambers cleaned and opened up around the valves. All good stuff but not cheap.
I have tried to contact Dimond about them re profiling the pistons and I have called after hours and during lunch the three times I called.
Someone joked about stacking gaskets sounded sketchy to me but they are layers already. The no answer sponsor and Livernois recommended .060 is the biggest. Do you guys agree? .051 to .060 is about 12.5 to 12.2(maybe 12.1) so if I could get a gasket at .065 or .070 then it would be solidly in the 11s and pump gas comfortable.
Livernois, maybe they aren't listed here on PT but they are on LS1tech
I not sure why I didn't go to cometic already. They have a gasket that is .066 and that would bring it below 11.9:1 perfect for anyone running pump gas.
Thanks for stating the obvious koots. I went from the advice at both shops of staying .060 or thinner. But for anyone who is concerned they can get a bit more comfort with an extra 6 ten thousandths.
