Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Regency rst brakes?
Old 09-22-2011, 11:19 AM
drummer22's Avatar
Default Regency rst brakes?
What kind of Pads do I need? 2007 regency rst big brakes up front i guess there bear brakes. with drums in the rear.
Old 09-22-2011, 04:19 PM
Silver05Rst's Avatar
as far as i know all the RST Regency brakes came with a bigger rotor but the caliper and brake pads were still stock from the factory.
Old 09-26-2011, 08:50 PM
1quickRST's Avatar
I believe the RST'S run a HD caliper up front. I remember reading the stock brake pads don't fit. Read through the RST sicky. Its in there somewhere.
Old 09-30-2011, 07:57 PM
RED04REGENCYRST's Avatar
Anything before 05 uses the standard 1500 pads. 05 and up it is a toss up between the 1500 and the hd setup, but all rst's used a oem size pads on the front.
Old 01-17-2012, 06:19 PM
ElktonsDG's Avatar
i remember hearing or reading that the brakes are baer brakes, but look up regencycustomparts.com they are in fort worth, texas. they bought everthing from rengency when they went out of business.
Old 01-17-2012, 06:26 PM
The rotors are either baer or ssbc depending on what year you have. The calipers and pads are oem.
Old 01-17-2012, 10:58 PM
formerly Stroked-DSM (11/24/2010)
CHILLLLLL's Avatar
They have a Baer Eradispeed kit or an SSBC kit as previously mentioned. All it is is a caliper relocation bracket coupled with a larger rotor. Caliper and pad is stock
Old 01-18-2012, 04:16 PM
Is there a way just to buy new rotors or can I run a SSBC rotor if I have Baer's?
Old 01-18-2012, 04:24 PM
You can call baer and get the part numbers for the front (14" eradispeed 2 piece) and rears (13" 1 piece), but the last time I called they wanted $200 per rotor. So I went back to stock.
Old 01-18-2012, 05:36 PM
Thanks. I guess I could get the stock size front and rears, but cross drilled and slotted? That should work right?
Quick Reply: Regency rst brakes?
