Garage Clean Out - Lots of Random Goodies
Looking to sell a collection of parts I have. Most of these things I'm going to throw away unless someone wants them. All stock parts are from my '01 ECSB 5.3L. All parts are intended to fit this vehicle, but some parts fit others years/models and obviously universal parts will fit anything.
I wasn't sure what to price a lot of these things at, so the prices are OBO, but please consider shipping costs when making an offer.
I'll continuously be updating this thread as I find more parts.
Items are first pay first serve.
- Stock 706 heads: Used, come assembled as shown, no issues, removed to put on aftermarket heads. Will ship to a head porter if you want. $100 shipped (heavy!)
- 799 valve springs: New take-offs, springs only, full set. I don't think these are anything special, they have faint pink stripe on the sides. $40 shipped
- LS1 cam: Used, came out of an '00 LS1 so this is the more aggressive of the LS1 cams. It was a nice upgrade over the stock 5.3L cam, helped a lot in the top end. In great shape. 202/210 0.496/0.496 116 LSA. SOLD
- Stock lifters: Used, all good. $15 shipped.
- LS7 lifters: Used about 1000 miles. $70 shipped
- Stock pushrods: Used, all fine and straight. $15 shipped
- Stock rocker arms: Used, all good. SOLD
- Stock exhaust valves: I have six 1.59" and two 1.55". I believe they were all new and came in a new set of heads. I have put about 500 miles on them. $Make offer.
- Stock coil packs: Used, good condition, switched to heat sink coils to use 90deg plug wires. $70 shipped.
- Stock plug wires: Used, all in good condition. They don't have the metal shield or springs, used those on the new plug wires. $Make offer.
- Oil pressure sensor: New, ACDelco D1818A, 2 pin: SOLD
- Stock coolant crossover/steam tube: Used, good shape. 2 ports, not 4 ports like the f-body LS1 crossover tubes. $Make offer
- Steam tube blockoffs: Used, one has the nipple broken off but it is not needed. $10 shipped
- Vacuum block. Used, good condition but polished finished is a little scuffed up. Three 1/8NPT pressure ports. 3/8” line to vacuum source. $20 shipped
- -10AN 45deg hose end: New, not sure what brand. Has a brass ferrule. $8 shipped
- Turbo oil feed and drain flanges: All new for T4/T3 turbo. One feed is -4AN with 0.04” restrictor built in, the other is 1/8” NPT female. Oil drain is for 5/8” ID hose. Have one gasket for feed and one for drain. $Make offer
- Silicone couplers: All new. 4”x4” 90deg, 4”x4” straight, 3”x3” straight, 4”x3.75” straight. $Make offer
- Stainless t-bolt clamps: All new. I believe the sizes I have are 4”, 3.75” and 3.5”. $Make offer
- 4L80E Transgo HD-2 parts: New. Few leftover parts if anyone wants them. 3-piece separator plate for dual feed, pressure relief valve, boost valve, gaskets, pan gasket (not pictured), $Make offer
- Random 4L80E parts: All used from 99 unit that was in perfect condition. Input shaft, forward clutch hub, main shaft, bolt-on yoke output shaft, clutch steels and frictions. $Make offer
- 4.56 gears: Used about 5k miles, USA Standard, GM 8.5/8.6” 10-bolt. Zero noise, good wear pattern. Pinion bearing dinged from uninstall, will need to be changed. Broken in properly. SOLD
- Gear install shim kit: New, GM 8.5/8.6” 10-bolt. Collection of carrier and pinions shims from two install kits: SOLD
- Carrier bearings and races: New, GM 8.5/8.6” 10-bolt. Koyo brand, came with the Ron’s install kit but weren't needed. SOLD
- Pinion crush sleeves: New, GM 8.5/8.6” 10-bolt. SOLD
- Gorilla wheel installation kit: Only used 20 of the lugs and the 4 locks & key, the rest is new. Comes with 28 lugs, 4 locks & lock key, and 4 valve stems. Part number 91945XLHT. SOLD
- Stock front coil springs: Used, good shape. SOLD
- Stock 16" wheels: Used with Cooper tires and caps, and I also have the spare. All in good shape, minor curb rash, no bends or cracks. SOLD
- Belltech 1* pinion angle shims: New, 2.5" wide. $15 shipped
- Pro Comp 2* pinion angle shims: Used, 1.75" wide. $10 shipped
- Leaf spring pack bolts: New, came with the Belltech shims, will include for free with either of the shims.
- LED 3rd brake light: New from eBay, it's the one in the pics with the tinted center and clear cargo lights. I tested it and it works great. $30 shipped
- Trailer wiring: New, came with the truck but never needed it, not even sure how it's used, GM part# 15366255. SOLD
- 5-speed steering column trim: Used briefly, perfect condition. Fit's 99-02 (maybe newer?). Since it's for the 5-speed manual is does not have the cutout for the shifter, perfect for clean T56 swaps. This part is discontinued and really hard to find. Interior color is graphite gray. SOLD
- Stock brake caliper brackets: Used, in good condition. Replaced with Baer front brakes and SUV rear brakes. $Make offer
- Stock brake lines: Used, in good condition. Replaced with stainless lines. SOLD
- Fuel pump: New, came with a new fuel bucket but I swapped to a Walbro 400. Unknown brand, no markings on it. It's not a Walbro or OEM brand. $20 shipped
