Used Parts (Mostly Stock)
Old Oct 2, 2013 | 06:11 PM
bfurches's Avatar
Default Used Parts (Mostly Stock)
Cleaning out the garage of all my excess. Feel free to make an offer, and if you are looking for something you don't see....just ask....I might have it.
All parts are located in the Springfield - Westfield MA area.
Thanks for looking,
Brandon
413-455-9795
-LS4 Intake Manifold Complete- 150.00
I have a complete LS4 Intake Manifold complete with throttle body, rails, and injectors
-LS3 Intake Manifold BRAND NEW- 250.00
Brand New never run LS3 Car Intake. NO rails or injectors.
-Crankshafts 5.3L- 125.00
I have two of these out and in good shape. One is a 58x and the other is 24x
-5.3L Bare Block- 100.00
I have a stripped 5.3 block with main caps. Perfect for a build. Can include the 3 covers for an additional 75.00
-5.3L Rods and Pistons- 100.00
I have a complete set of 5.3 Rods and Pistons x2.
-2004 4.8L LR4 Stock Camshaft- 40.00
-1999 6.0L LQ4 Stock Camhaft- 40.00
-706 Casting Cylinder Heads *CORES*- 75.00
These heads are complete but in rough shape (corroded and filthy). They would be best for someone turning in for CNC work, or if you wanted a solid set to port.
-2005 Corvette Harness- 250.00
I don't know a whole lot about this, it is off a 2005 Vette and uses the three PCM connectors as opposed to the normal E38 2 connector.
-1999 6.0L PCM and MAF- 100.00
Removed from a 4wd
-Coil Harnesses- 50.00 per set
These are the small harnesses that separate from the primary, but daisy-chain each bank of coils together.
-Valve Covers- 25.00 per set
-Valley Cover Gen III- 25.00
-Front Cover Gen III- 30.00
-Complete Coil Assembly Standard- 150.00
Includes full set of 8 coils with bracket and harness.
-Complete Coil Assembly Heat Sink Style- 175.00
-Truck Oil Pan- 75.00
Includes windage tray and oil pump pick-up tube
___________________________________________
-Complete Truck Accessory Setup- 100.00
*Includes all the itemized parts below. Does NOT include a power steering pump or alternator)
*-Truck Alternator & Power Steering Bracket- 50.00
*-Truck AC Compressor Bracket- 30.00
*-Truck Water Pump and Clutch Fan- 25.00
*-Truck Crank Pulley- 30.00
-Complete DBC Truck Intake, Rails and Injectors- 80.00
-Truck EGR Exhaust Manifolds- 30.00
-Truck Non-EGR Exhaust Manifolds- 40.00
-LS4 Exhaust Manifolds and Cross-Over- 75.00
Good for a Budget Turbo setup.
-4L80E Flat Flexplate- 40.00
-4L60E Concave Flexplate- 30.00
Size:  95.8 KBName:  temporary_zps7b2712d1.jpg
Old Oct 4, 2013 | 02:41 PM
bfurches's Avatar
Added a few items, sold a few items.
If you don't see what you are looking for....ASK!
Old Oct 4, 2013 | 11:55 PM
Staggered 02's Avatar
Hi interested in the accessory bracket assembly you listed. What shape is the bracket in? I picked one up not long ago but found out it had a cracked fastener attach location. Where is this shipping from? Can you please send or post some pics? Thanks.
Old Oct 7, 2013 | 04:00 AM
1bad2k's Avatar
Happen to have an 80e flexplate with spacer?
Old Oct 7, 2013 | 03:29 PM
bfurches's Avatar
The brackets are dirty but in good shape. I can always sandblast one and shoot it with some paint for a few extra bucks. Are you just looking for the main bracket or the AC as well?
Shipping out of Springfield MA
No spacers at the moment...just the plates
Old Oct 21, 2013 | 07:49 PM
cammed00's Avatar
Would you sell the maf seperate? Need one for 04 tahoe
Old Oct 23, 2013 | 09:40 PM
bfurches's Avatar
Yes...I have a few different MAFs. What engine do you have? By chance do you have a part number?
Old Oct 23, 2013 | 09:54 PM
cammed00's Avatar
Old Oct 23, 2013 | 10:28 PM
bfurches's Avatar
5.3 and I can get a part # tomorrow
sounds good, I'm sure I have one.
Old Oct 23, 2013 | 11:35 PM
cammed00's Avatar
Pic added
