Atomic's Christmas Sale
Old Dec 4, 2011 | 06:47 PM
Atomic's Avatar
I have a gauge for that
Default Atomic's Christmas Sale
New detail guys, Ill donate half of whatever stuff sells for to budhayes3's daughter Rosie in light of recent events.
I can get pics of everything if I need to. Everything is OBO + shipping and fees, but pm me and we can work something out.
TR 224-112 - 224/224 .563/.563 112 LSA cam, excellent shape, has about 15k on it. SOLD
OEM 3.73 8.625" (10 bolt) Ring and Pinion gears, 150k, SOLD
Yukon 4.56 9.5" (14b sf) Ring and Pinion gears, 20k, $100
L92 intake gaskets, good shape, $25
L92 fuel rail, good shape, $50
L92 intake, bare, $100
L92 intake cover, $60
Pro-comp traction bars for 99-07 with install kit and all hardware for halfton. SOLD!
99 blue center jump seat, lid is broken, $20, dont want to ship
99 water pump (minus fan), works fine, $40
99 coolant res, $15
99 vacuum brake booster, $20
99 5.3 radiator, good shape, $50
99-07 ac compressor bracket, $20
2 sets of rear 2in lift blocks from a stock 4wd, $20 per set
set of rear ubolts for stock 4wd, $10
4l60e -6an cooler fittings, brand new, $20
99 fuel lines w/filter complete from tank to engine, $100
99 stock transmission cooler lines from trans to rad, $50
99 ypipe with cats, uncut, $150, dont want to ship
99 catback exhaust with what looks like a flowmaster 40, I will cut off the muffler or connector if someone wants it, $25 for both?
99 reg cab short bed 4wd rear driveshaft, $60
07+ rear wall carpet and insulation, grey, good shape, $50
99 complete fuel pump assembly, works, $60
99 stock cluster (100mph), works but has a crack in the bottom left of the plastic cover, SOLD
99 complete intake tube, airbox, $30
Just added:
99 power steering pump, works fine, $50
2 sets of stock plug wires, $15 per set
4l60e to 4l80e 4wd conversion crossmember, SOLD
4l60e transfer case adapter w/bolts, $50
4" mandrel bend 180deg exhaust pipe, brand new, $40
Oil filter sandwhich plate (red) for an external oil filter, never used. 2wd only, on 4wd it hits the driveshaft. SOLD
Oil filter sandwhich plate for monitoring temps or a turbo feed, barely used. SOLD
http://i11.photobucket.com/albums/a1...2983Custom.jpg
http://i11.photobucket.com/albums/a1...2985Custom.jpg
http://i11.photobucket.com/albums/a1...2987Custom.jpg
http://i11.photobucket.com/albums/a1...1997Custom.jpg
Forgot about this little guy. Perfect for anyone who needs a simple turbo feed. Tapped for 1/8npt I believe, fitting is -4an. SOLD!
http://i11.photobucket.com/albums/a1...0284Custom.jpg
Old Dec 4, 2011 | 08:32 PM
probuilder1's Avatar
How mush for the pro comp bars shipped to 23185?
Old Dec 4, 2011 | 08:44 PM
kalikid06's Avatar
will the bucket and sending unit work on an '06 silverado?
Old Dec 4, 2011 | 09:59 PM
Atomic's Avatar
Sent you a pm.
No, the buckets for 99-02 are the same while 03+ are different.
Old Dec 4, 2011 | 10:06 PM
GONEB4U's Avatar
10 Second Club
Do you have a pic or a part # for the 6 an trans fittings?
Old Dec 4, 2011 | 10:10 PM
Atomic's Avatar
Yea, they are exactly this: Russell Performance 640520 - Russell Transmission Cooler Line Fittings - Overview - SummitRacing.com
The ones I have a brand new. I ordered these without realizing they are for an 60e, not an 80e. I called 30 minutes later to cancel but it was too late. If you are thinking about just buying those off summit, mine would be $25 shipped and summit would be $32 shipped for the same thing.
Old Dec 4, 2011 | 11:40 PM
Atomic's Avatar
3.73s sold
Old Dec 5, 2011 | 06:00 AM
joeyc125's Avatar
11 Second Truck Club
Pic of the 120 mph speedo. Mines only 100mph, thought only the Denali or esky ones went 120?
Old Dec 5, 2011 | 08:32 AM
pjku79's Avatar
What did you have that cam in? I am looking for something mild for a 5.3L.
Old Dec 5, 2011 | 09:32 AM
Atomic's Avatar
I just doubled checked, it only goes to 100mph. My bad.
Several members have had this came including bumpers, and fastsrt. I came to have it out of a trade. Its a little big for a 5.3 if you are seeking mild.
Added some stuff:
4l60e to 4l80e 4wd conversion crossmember, $75
