Rhino's Turbo LQ TOYOTA TUNDRA
Old 03-23-2011, 02:30 AM
rhinosarge's Avatar
Default Rhino's Turbo LQ TOYOTA TUNDRA
so .. please .. not all at once. i know theres a millions questions.. but i have a million questions of my own to ask ALL YOU TURBO GURU'S
2005 LQ4 off hd2500
ARP STUDS <NEW
YELLOW SPRINGS <NEW
Z06 CAM <NEW
MOTOTRON 60lb <NEW ---> WHAT CONNECTORS DO I NEED? EV6 TO EV1?
2008 TRAILBLAZER MANIFOLD
BBK 80MM CABLE TB
EBAY INTERCOOLER
38MM TIAL WASTEGATE W/ 8LB SPRING
38MM HKS BOV
my harness was custom made.. no MAF, no rear o2's.. no park neutral safety .. runs off speed density and IAT sensors.. (mind went blank)
oil pan has a new plug welded to the front cause off install cant reach stock location
turbo is a small turbo .68 hot side from the STS 6.0 gto kit.. i dont need a huge turbo since ill be in the sand a lot!!!
dont need a stall either for that same point...
3IN CUT OUT .. I HAVE A AEM WIDEBAND AS WELL
need to figure out how to run intercooler pipes.. oil supply.. radiator & fans..
and install the b&m shifter to the 4l60e
here some pics.. enjoy.. its not installed yet..
older pics
Old 03-23-2011, 03:27 PM
Alpinestar's Avatar
I'm pretty sure your factory connectors are the mini Delphi type. EV1's are found on ls1 engines.
Old 03-23-2011, 05:17 PM
rhinosarge's Avatar
i have the stock 2002 escalade connectors for truck manifold
and now i have the 60lb mototrons..
Old 03-23-2011, 05:21 PM
1slowz71's Avatar
UR GAY !! hurry up get it running already!
Old 03-23-2011, 05:39 PM
rhinosarge's Avatar
so much for your cousin coming to help me with the cam swap..
i did it all by myself!! the long block is ready to drop in tomorrow.. but the damn rain is killing me!!
Old 03-23-2011, 05:44 PM
1slowz71's Avatar
you already know how he is ! but man little by little its coming along !
Old 03-23-2011, 06:00 PM
rhinosarge's Avatar
you shoulda gotten those arp studs man.. 100 bucks!!
Old 03-23-2011, 11:02 PM
WhoDunIt's Avatar
Pretty sweet setup. I'm working on an LS swap in my 66' Bronco, building it up for long travel suspension as well.
Old 03-23-2011, 11:10 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Please post up a build thread in the projects section. Im a GM man through and through but Ive got a very big soft spot for teh first gen broncos, Ive got 4 of them in various conditions of disarray but one day one will have an LS and long travel suspension
Old 06-27-2011, 04:31 PM
1slowz71's Avatar
New name for this build is LAMICKEYMOUSE
Quick Reply: Rhino's Turbo LQ TOYOTA TUNDRA
