Fs: B&m 70297 hi-tek trans cooler with e-fan
B&M 70297 Hi-Tek transmission cooler with e-fan.
Less then 2000 miles on this.
It also has the AN fittings as well as the stock trans line adapters & is included. You will need some hardware & 2 1/2 ft. piece of 3/4" aluminum L angle for the lower brace that you see in the picture to mount it properly.
SOLD
Post up or pm me if your interested. Thanks
Here is some info from B&M's site:
Hi-Tek Automatic Transmission Cooling System 13-1/2"x9"x3-1/2" with 9-1/2" diameter fan
Fitted with a high quality 12 volt electric fan and built-in mounting brackets, these coolers handle tough cooling jobs. They include a thermal switch to activate the fan when the fluid temperature reaches 175 degrees F. Can be used for racing, RV and street performance vehicles. Suitable for all fluid cooling needs including: automatic transmission fluid, engine oil, differential fluid, power steering and turbocharger oil in circle track, road racing, off-road, tractor pulling and monster truck applications.
SOLD
MA$TER_E
Sep 9, 2015 03:14 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
