Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > WELCOME TO PERFORMANCE TRUCKS.NET > Projects Gallery
Old 01-24-2010, 02:54 PM   #1
exodus
Trader Rating: 11
exodus's Avatar
Send a message via Yahoo to exodus
Default OBS 97 Z71 05 5.3 and Radix Swap
I am active duty army, and have been in Iraq for a year. While I was there I have been thinking of using some of my hard earned money to get another truck. Mine has 213,000 miles on it, but I love it to death. It has been so good to me over the years that I decided to put the money into it rather than to get another truck. So I did my research and figured out what I wanted to do for the build. This is what I have come up with.
2005 5.3 with 60,000 miles complete and with harness and computer.
Also have a ZO6 Cam, Hardened pushrods from comp, Patriot gold spring kit, TSP ported oil pump, Heavy duty GM roller timing set, MP122HH Radix (moregrip's complete old blower setup), and a FLT Level 4 4L60E with a Yank SC2800 Converter.
Got the engine on the stand, and began tear down yesterday
__________________
2005 5.3, 122HH Intercooled Radix, twin billet 100mm idlers, 3.1 pulley, ported and polished matched 90mm TB and J tube by WCCH, 60# injectors, 2004 ZO6 Cam, GM heavy duty roller timing set, TSP ported oil pump, Comp Hardened pushrods, Patriot Gold dual valvespring kit, Arp fasteners, FLT level 4 4L60E, Yank SC2800 converter, 05 E fans, Magnaflow high flow cats, Flowmaster 40, 32" NITTO Terra Graplers
http://www.performancetrucks.net/for...d.php?t=455832
exodus is offline   Reply With Quote
Old 01-24-2010, 02:58 PM   #2
exodus
Trader Rating: 11
exodus's Avatar
Default more of the teardown
__________________
Old 01-24-2010, 03:01 PM   #3
exodus
Trader Rating: 11
exodus's Avatar
Default Just a few more
pulling the cam
2005 ZO6 Cam going in!
__________________
Old 01-24-2010, 03:05 PM   #4
exodus
Trader Rating: 11
exodus's Avatar
Default Goodies arrive!!!
few things from TSP...
GM Gaskets, ARP crank bolt and head bolts, ported oil pump, and fuel pump kit
loctite on cam bolts
new GM heavy duty roller timing set, and oil pump installed
__________________
Old 01-24-2010, 03:09 PM   #5
exodus
Trader Rating: 11
exodus's Avatar
Then came a moment of stupidity on my part. I have no idea why i did this, but as I was reinstalling the oil pan, I tightened the front corner bolt on the driver's side too much, and the spot where the timing cover meets the pan pushed the pan to crack it as i tightened the bolt. Carnage insued and this is the result...
__________________
Old 01-24-2010, 03:10 PM   #6
turboescalade
Trader Rating: 9
turboescalade's Avatar
Send a message via MSN to turboescalade
pretty excited to watch this build man!!!
__________________
.591, .601 lift... 115 LSA...230/236 duration,edelbrock heads massaged by richard at WCCH, TVS 2300 (cog overdrive rear, 3.2 8 rib up front) long tube headers, 408 (9.5:1) waiting to put together and throw on the dyno!
turboescalade is offline   Reply With Quote
Old 01-24-2010, 03:29 PM   #7
exodus
Trader Rating: 11
exodus's Avatar
Glad to have you on board! lol I am excited to finally be doing it! There will be a lot to this, and I am going to do my best to document everything the best I can....good and bad as you can see.
__________________
Old 01-24-2010, 03:31 PM   #8
exodus
Trader Rating: 11
exodus's Avatar
would like to point out that when i had this oil pan mishap i posted an ad to find one here in the classified section, and had someone help me out in less than 5 minutes! The network and people here are incredible. "chevytruck" came through for me right away so I should have the pan by the end of the week.
__________________
Old 01-24-2010, 03:53 PM   #9
sierraSS
Trader Rating: 0
will follow. im going to do this swap soon too. just need to piece my engine together
sierraSS is offline   Reply With Quote
Old 01-24-2010, 05:34 PM   #10
exodus
Trader Rating: 11
exodus's Avatar
FWIW I did research for about 6 months prior to this build, and it is paying off tremendously.
__________________
Tags
53 , 60 , 97 , badest , build , cost , gold , obs , pump , springs , swap , trucks , tsp , water , z71
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
