Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > TRUCK PERFORMANCE & GROUP DISCUSSION > Forced Induction
Old 12-17-2009, 11:03 PM   #1
SimpleManLance
Trader Rating: 8
SimpleManLance's Avatar
Send a message via AIM to SimpleManLance
Default motor for 122hh, 10psi + 75 shot
i have a 03 6L that i want to use as a base for this motor. what would you do to the motor? cam? forged rods, pistons? what brand? this would deffently have to be a buget build $2-2500 limit for the long block.
i figure 10psi should be good enough to stay away from belt slip issues, and heat problems. and if i feel the need for more power i will spray a 75 shot.
i figure i would spin the motor up to 6k max and just try and make as much power up till then.
how would you build this motor and why?
__________________
Lance
2000 GMC Sierra Z71 5.3
Flex-a-lite electric fans, 160 degree stat 3in hooker Aerochamber, cutout, pacesetter lt and ORY, 4l80E swap, 255LPH, 02 ls6 cam, 90mm TB, 122HH, 3.2 pulley.
SimpleManLance is offline   Reply With Quote
Old 12-18-2009, 04:43 AM   #2
old motorhead
Trader Rating: 4
If I had to rebuild my LQ4 for MP122 duty, I'd use Eagle H-beam rods, forged pistons, and use the stock crank. Aim for about 10:1 c/r. I like the LS6 cam and high lift rocker arms that I'm using now. That won't change. I might port the heads a little, but that would be out of your price range. I'm at 9psi (2.8" blower pulley) on my stock short block LQ4. I'm hoping it will last a while longer. I have a 75 shot on it, but use it only at the track.
__________________
Work: '05 GMC RCSB 6.0L Radix MP122, 243 heads, 4L80E, LT's, custom blower cam, extremely black.
Play: '08 Vette, LS3, TVS2300, custom blower cam, LT's, ZR1 clutch, NPP mufflers, extremely quick.
old motorhead is offline   Reply With Quote
Old 12-18-2009, 05:49 AM   #3
Low_LSX
Trader Rating: 33
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
Send a message via MSN to Low_LSX Send a message via Yahoo to Low_LSX
Probe 6.125 4340 I-Beam Connecting Rods
Probe Forged Flat Top Pistons -3cc reliefs
Federal Mogal Main/Rod Bearings
Stock Cam Bearings
ARP Main Stud kit part#234-5608
springs/titanium retainers/stock locks
GM MLS Head gaskets
Melling oil pump 10296 w/ blue spring.
I'd get a Custom Cam but a GT2-3 would also work.
__________________
A.J.
Coming soon
2000 GMC Sierra RCSB
.............. - Action Speed & Machine LSX 376 - ARP - Meziere WP319S - DBRODS Custom Fuel Cell - PatrickG Custom Cam - Nasty Performance Coil Relocation Bracket - Ron Davis Radiator - ARH 1-7/8 - 3' X Pipe with Dual Magnaflow Mufflers - 4l80e - B2 Circle D Converter - L92 Vic Jr - Intake Elbow - 90MM UMI - QA1 Adjustable - LS Water Vapor System Made by Kurt Urban Performance - 4/6 DJM - CalTracs - Boyd Coddington Starburst.
Low_LSX is offline   Reply With Quote
Old 12-18-2009, 05:50 AM   #4
sharpshooter
Trader Rating: 6
does the 03 6L have any internal problems?
__________________
6.0 LQ4/crane cam 216 224 .551 .551 lsa115/Procharger D1SC,3 core FMIC/044 Bosch in tank/60# motrons/Pacesetter LT, ORY and Corsa cat back with Magnaflows/perma cool fans/Circle D 12" billet converter/FLT4L65E LVL5 with billet output/Yukon 4.11's front and rear [9.5" 14 bolt]with eaton posi / Coolingmist meth/PLX wideband/ JUSTIN TUNED and a few other mods
12.4 @ 108 4.0" pulley high 30 degree weather
12.6 @ 105 3.7" pulley high 70 degree weather
as you see it in the pic
sharpshooter is offline   Reply With Quote
Old 12-18-2009, 05:50 AM   #5
SimpleManLance
Trader Rating: 8
thanks for the reply. what times do you run with out the 75 shot?
__________________
Lance
Old 12-18-2009, 05:57 AM   #6
SimpleManLance
Trader Rating: 8
the 6l has 95k miles on it. ive never heard it run. i bought it with the intention of tearing it down and building it.
__________________
Lance
Old 12-18-2009, 06:31 AM   #7
old motorhead
Trader Rating: 4
Quote:
It has run low 12's. Hope to get into the 11's this weekend with the cooler weather.
__________________
Old 12-18-2009, 08:35 AM   #8
moregrip
Trader Rating: 5
who's that baddest mofo?
moregrip's Avatar
your going to eat up 2-2.5k fast doing things right even on a budget build. I don't see it happening for that $$ amount. I would save more money and run the stock motor until it pops
I would contact local engine builders and see what they are willing to do, get some estimates, make sure they know what they're doing, make sure they are reputable. Anyone not local to you would obviously add shipping $$.
__________________
2005 Chevrolet Silverado 2500HD ECSB 2WD
365 CID motor built by "Rex", Magnuson TVS 2300,WCCH StageII LQ9 heads, EDC Cam, SW Headers, Magnaflow Exhaust, CPT 4L80E, PI 2800 TC, TRACK: Real Racing 16x12 wheels, M&H DOT Cheater Slicks, STREET: Intro Pentia 8 20x10 wheels, BFG KDW's
moregrip is offline   Reply With Quote
Old 12-18-2009, 08:49 AM   #9
Midnightrider
Trader Rating: 1
Midnightrider's Avatar
Send a message via AIM to Midnightrider
2000- 2500 will get you half a short block. If i were you ide get a good set of heads and cam and run it on you stock short block
__________________
LSX 447ci Twin turbo Under contruction 1000 to the wheels or bust) HPM built 4L80e, HPM E-Fans, , 2Aeroforce guages,3" Mandrel Magnaflow true dual exhaust, SS bumper, Seamless role pan, SPRAYED99 tail lights, Cowl hood, SS grill, Beltech 2/4 nitro drop, Black Chrome Boss 313s , KW Excelon touch screen, Diamond Audio D3 10" subs D6 door components 1500 watts 3% tint 35% windsheild, Clifford 3.5 , HIDs
Midnightrider is offline   Reply With Quote
Tags
block , core , lq4 , sale
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
