Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > GM General Discussion
Old 05-30-2009, 04:42 PM   #1
00ChevyScott
Trader Rating: 8
Wearin' da big hat
00ChevyScott's Avatar
Default Can you run E85 with marine injectors?
I know the fuel rail and everything is different as well, but with the proper tuning, would you be able to run E85 fuel on a non-flex fuel engine?
__________________
It's all about the HONDA LOVE!!!
1997 Honda Accord SE 2.2L A4
00ChevyScott is online now   Reply With Quote
Old 05-30-2009, 05:34 PM   #2
Low_LSX
Trader Rating: 33
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
Send a message via MSN to Low_LSX Send a message via Yahoo to Low_LSX
I don't see any reason not to run it. If I remember correctly KBracing was running E85 with his stock truck intake and 42lb injectors.
__________________
A.J.
Coming soon
2000 GMC Sierra RCSB
.............. - Action Speed & Machine LSX 376 - ARP - Meziere WP319S - DBRODS Custom Fuel Cell - PatrickG Custom Cam - Nasty Performance Coil Relocation Bracket - Ron Davis Radiator - ARH 1-7/8 - 3' X Pipe with Dual Magnaflow Mufflers - 4l80e - B2 Circle D Converter - L92 Vic Jr - Intake Elbow - 90MM UMI - QA1 Adjustable - LS Water Vapor System Made by Kurt Urban Performance - 4/6 DJM - CalTracs - Boyd Coddington Starburst.
Low_LSX is offline   Reply With Quote
Old 05-31-2009, 10:20 PM   #3
joeyc125
Trader Rating: 4
yeah, i have been running it for a while now with those injectors. For tuning i just scaled down the injector values by the percentage of the difference in stoich value, i would have to look on my other computer for the tune but i think i entered them as 32lbs? Fuel trims are right on and my wideband says 12.6-12.9. Your wideband will still give you gasoline readings, which you should see the same numbers as gas.
__________________
370-TC76-215-224-114-PB 60e-10.5 Billet 2800 TC-3.73's-TrueTrac
Old Setup: TVS 1900 @ 6psi 12.87@104
00 RCSB Z71 Soon to be spooled...
"If you can't fix it with a hammer, you have an electrical issue"
joeyc125 is offline   Reply With Quote
Old 05-31-2009, 10:32 PM   #4
kbracing96
Trader Rating: 18
Truck Sponsor
kbracing96's Avatar
Send a message via AIM to kbracing96 Send a message via MSN to kbracing96
Ya, you can run E85 on any injector as long has it's large enough to support the power you looking for. With E85, you need about 30% more fuel for the same power as gas.
I love the stuff and would run it more if I had good access to it. It's like running cheap race gas. If your not flex fuel, then you have to be tuned for it. If your not looking for max out of it, then it is possible to setup a tune using fuel trims to run both fuels but you will compromise both ways. Best power will come with tuning for the fuel your gonna run. The stock fuel system in these trucks is compatible with the ethanol fuel.
__________________
01 ECSB, Forged 5.7 LS1, 4x4, GMC: 12.21@110.5 at 4800' (DA 7000', old MP T70 turbo setup)
KB 2.8l air heater
FULL Line of EFILive and Innovate Products!!!
AUTHORIZED Master Power, BW Airwerks and Turbonetics Dealer!!!
PM or Email for details
Kbracing96@gmail.com
kbracing96 is online now   Reply With Quote
Old 05-31-2009, 10:35 PM   #5
00Silv4.8
Trader Rating: 10
2003 Chevrolet Silverado 1500
My Garage
00Silv4.8's Avatar
E85 doesnt have much advantage over gas does it? Other than a higher 'octane' rating right? no MPG gains? Just wondering cuz I dont see why it would be worth any trouble to jump thru all those hoops if you're not at least F.I.
__________________
http://i271.photobucket.com/albums/j.../OldandNew.jpg
LQ4//Lunati//241's//80e//LT's//Tuned? R.I.P. Beast
'04 Gix 6-Passion not fashion
'03silv5.3
Quote:
Originally Posted by 03chevyroyce View Post
yall are some freakin fanny bandits
00Silv4.8 is offline   Reply With Quote
Old 05-31-2009, 10:38 PM   #6
2005 Silverado
Trader Rating: 16
SPAM HUNTER
2005 Silverado's Avatar
Send a message via ICQ to 2005 Silverado Send a message via AIM to 2005 Silverado Send a message via MSN to 2005 Silverado Send a message via Yahoo to 2005 Silverado
Im pretty sure the mileage goes down. But the cost is less so it equals out.
Dustin
__________________
DUSTIN
4.8/LS6 CAM/KBR FRONT MOUNT/CORSA/TRUTRAC/4.10'S/4L80E/EFI LIVE TUNE
2005 Silverado is offline   Reply With Quote
Old 05-31-2009, 10:52 PM   #7
viciousknid
Trader Rating: 3
viciousknid's Avatar
Send a message via MSN to viciousknid Send a message via Yahoo to viciousknid
I've seen mileage equivalent to weight. Cars usually pick up mileage while trucks break even and suv's lose.
At least that was the case in a test I saw.
__________________
-Joshua
5.3 ECSB|XR269HR|LS6 Springs|LT ORY XR1
FLT4|COS3 SD EFI Live|Circle D 3000 stall|4.30's|truetrac|AEM Wideband
[a href=http://www.nitrousoutlet.com][/a]
To Err is Human. To ARRR is Pirate.
viciousknid is online now   Reply With Quote
Old 05-31-2009, 10:57 PM   #8
kbracing96
Trader Rating: 18
Truck Sponsor
kbracing96's Avatar
Na is not much of an advanage, but fi like I said Its like running cheap race gas all the time. 105 octaine is nice. I did loose about 2 mpg's with it.
__________________
KB 2.8l air heater
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
