Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > WELCOME TO PERFORMANCE TRUCKS.NET > Projects Gallery
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Old 03-05-2009, 12:08 PM   #1
sss408
Trader Rating: 0
sss408's Avatar
Default Silverado SS build
Ok guys ive looked around on this site alot and have been a member for alittle while but never post. Here is my current Project a 2003 Silverado SS it had a 408 in it for a while (low compression) but apparently i messed the rings up building it so after i decided i wanted turbo now and not a rebuild/fixed 408 i went ahead and bought a 4.8L to throw in the truck for now with the turbo, turbo set up is a GT-K 1000 (76 with .96ar) with trick performance hot parts and custom DP, I just installed rod bolts and main cap studs in the 4.8 and also have head studs for my 6.0 heads that im gonna polish up, also going ls2 intake for now will upgrade to fast 92 and 225 afr or trick flow heads on the 408, i also plan on running e-85 with a complete new fuel system, this build has been on ls1truck for a while where i post as 408.Luke btw
Here is a vid i made for the truck will make more as the build progresses
http://www.youtube.com/watch?v=ATMCB...e=channel_page
and some pics
studs and rod bolts
TU2 cam from Speed Inc
the 4.8 (80,000 miles)
dug around my tool box and found this! will be going on my tailgate closest to 4.8 i can find
emerald green-color that block, timing cover, intake, ect will be
truck as it sits now
__________________
03 SS Silverado- build in progress
4.8L w/ 80,000 miles rod bolts and main cap studs
317 heads w/ head studs
Turbonetics GT-K 1000
Trick Performance Hot parts and custom 4" DP
04 Duramax Diesel RC/LB White 4x4
HP tuners
Intake and Exhaust on its way!
sss408 is offline   Reply With Quote
Old 03-05-2009, 12:10 PM   #2
eddie_da_chevy_guy
Trader Rating: 3
Nice!
eddie_da_chevy_guy is offline   Reply With Quote
Old 03-05-2009, 12:17 PM   #3
TrickPerformanceProducts
Trader Rating: 3
Truck Sponsor
Good luck with the build Luke... I am sure the 4.8 will be just fine. Its been proven to make good power, just stay out of detenation.... You might like so much the 408 might need a different home.
__________________
Wideband w/ Sensor for 189.00
Angel of the 1 off!
TrickPerformanceProducts is offline   Reply With Quote
Old 03-05-2009, 12:23 PM   #4
sss408
Trader Rating: 0
sss408's Avatar
Quote:
ill do my best to keep it out of detonation the e-85 should help a bunch, ive had numerous offers on a new home for the 408 away from me but im not budging lol, i have been wondering how much i will like the set up for on the street, i think it should roll out hard from a 55 or so!
__________________
HP tuners
Old 03-05-2009, 12:28 PM   #5
Trader Rating: 3
Truck Sponsor
Yea, I keep forgetting you are running e85.. I wonder if there is even a need for an intercooler with that being you fuel source.
Also seeing how you are converting to e85 that means you will always need to run that fuel. No swapping in regular premium unless you have a back up tune in case no e85 is around.?
__________________
Angel of the 1 off!
Old 03-05-2009, 12:33 PM   #6
sss408
Trader Rating: 0
sss408's Avatar
yes i will have a back up tune i will be driving it to some towns with no e-85 but it will be a 12psi tune or so just to get me home/around at a slower pace lol
__________________
HP tuners
Old 03-05-2009, 12:49 PM   #7
00Silv4.8
Trader Rating: 8
2000 Chevrolet Silverado
00Silv4.8's Avatar
Pretty nice truck. Good luck with the build. Sucks you had to pull that 408
__________________
http://i271.photobucket.com/albums/j...uck/720092.jpg
LQ4//Lunati//241's//80e//LT's//Tuned? R.I.P.
Your heart will live on...
'68 C-10 RCSB-350/4L60e/LTs/Slow-SOLD
'04 Gix 6-Passion not fashion
'99 T/A T-56//LS1//Fun
00Silv4.8 is offline   Reply With Quote
Old 03-05-2009, 01:01 PM   #8
00ChevyScott
Trader Rating: 7
Wearin' da big hat
00ChevyScott's Avatar
Send a message via AIM to 00ChevyScott
I think that cam is going to bleed ALOT of boost in that 4.8 and is going to have no low end.
__________________
Cam only 5.3 ECSB
8.280 @ 82mph
The best movie clip ever hahahahha
00ChevyScott is online now   Reply With Quote
Old 03-05-2009, 02:34 PM   #9
built408
Trader Rating: 4
built408's Avatar
who spec'd that cam for you?
built408 is offline   Reply With Quote
Old 03-05-2009, 05:55 PM   #10
sss408
Trader Rating: 0
sss408's Avatar
its a speed inc grind, its one of 4 turbo cams that they sell its 2nd most radical, they have a TU3 that has bigger duration and lift
__________________
HP tuners
Tags
48 , houston , huston , quiks , sale , silberado , silverado , ss , turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Contact Us - PerformanceTrucks.net Forums - Archive - Top - Advertising - Privacy Policy - Terms of Use - Jobs
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
