Electric Fans - Pin 33
#31
Truck Sponsor
it does now
I am pretty sure the 03 and 04 are the same. I did it on my 04....
Here is the thread.
https://www.performancetrucks.net/fo...ighlight=efans
Hopefully your using EFI Live, cause HPtuners does not have the AC pressure adjust needed to control the second fan correctly....
http://www.hptuners.com/forum/showthread.php?t=8858
Here is the thread.
#32
Nonnie, how do you do it on a 99-02? I have the 03+ diagram, but I can't really read it. I have had some 05 fans for like a month just sitting at my brother's house because I have no idea how to hook them up. I want to use both PCM pins because I have the new HPTuners beta version. Please help!
#33
Here are some diagrams I have.
#1 similiar to Nelson Harness
#2 similiar to 05+ Gm Harness
#3 05+ Gm Harness
#4 05+ Gm Harness, I Modified for 2 fuses
The first one uses the ac as a trigger while the other three use the two pin setup. Not sure who uses #2.
#3 05+ Gm Harness
#34
Do yall just need the harness info???
I used this diagram.
run the wire thats suppose to go to the AC ground to the PCM pin 33 and activate it in the tune and Vola..
#35
Thanks man. installing the 34"rad and fans shouldn't be too much of a hassle if at all but wasn't sure how to get them running. I didn't want to use the same wiring as now and have them running constantly. Did you make your own harness or mod one?
#37
I made my own..
you can use Pin 33 and 42....
on EFI Live you go to System > A/C > Parameters
{G0106} A/C Auto Recirculatoin - Fan #2 Control
Then go to System > Fans> Parameters
{G1203} Type of Fans Fitted To vechicle - Series Parallel Fans
This is how the stock Fbody tune is setup..
here is my Fan settings BTW
I know HPT is different, but you get the idea?
