Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > GM Engine & Exhaust Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Old 08-20-2008, 02:07 PM   #1
Beast S10
Trader Rating: 0
Send a message via AIM to Beast S10
Default My exhaust project
I bought some used headers -
What they are new and specs :
http://store.summitracing.com/partde...0&autoview=sku
Here's my improvements :
Loose heat shield- welded up
Welded around the EGR tube better
Welded around each primary on the outside of the flange- I still need to grind some of the welds for bolt clearance.
Grinded the inside for better flow
One of the bungs was stripped on the drivers side collector- re tapped the thread and got nicer plugs. I will use high temp anti seize when I screw them in for good.
Grinded the air tube welds- found out they are brazed on. Can’t weld over that.
The Y pipe collector had some cracks and down the middle you could see light through. I welded up the cracks and I just need to grind out the welds smooth.
Once I finish grinding out the other header on the inside- I’m sending them to Jet hot to get ceramic coated and they will look good as new. Then I go to the exhaust shop and get the mid section on the Y pipe fitted and repaired. I also got new donut gaskets for the Y pipe.
I’m going to have 3” from the Y pipe to the muffler. I have a 3” stainless flex pipe that I’ll install before the high flow stainless cat I just got. Followed by a QTP cutout. I will also will have to weld in an O2 bung after the new cat for the third 02 Sensor.
I still need to buy bolts for everything- the headers, Y pipe and collector. Probably use ARP bolts.
anyway- here's some pics :
http://farm4.static.flickr.com/3065/...8dbb05.jpg?v=0
http://farm3.static.flickr.com/2154/...9f95b4.jpg?v=0
http://farm4.static.flickr.com/3284/...613dfe.jpg?v=0
http://farm4.static.flickr.com/3283/...2ef48c.jpg?v=0
http://farm3.static.flickr.com/2111/...6a1f29.jpg?v=0
http://farm3.static.flickr.com/2146/...baee60.jpg?v=0
http://farm3.static.flickr.com/2210/...34474d.jpg?v=0
http://farm3.static.flickr.com/2055/...77af08.jpg?v=0
http://farm4.static.flickr.com/3128/...333d7c.jpg?v=0
http://farm3.static.flickr.com/2237/...097186.jpg?v=0
http://farm4.static.flickr.com/3143/...c1dd25.jpg?v=0
http://farm4.static.flickr.com/3272/...2c16c7.jpg?v=0
Grinding all done- I also chopped out the Mid section of the Y pipe that was crunched from hitting a speed bump. I also had to retap another bung on the Y pipe- it was crossed a little bit. I'll get the new section welded in when I get the headers on the truck. I'll probably drive my truck open headers to the shop and fit the Y pipe and the rest of the exhaust.
Pics :
[url]http://farm4.static.flickr.com/3062/2427023142_3b3683cf9a.jpg/url]
http://farm3.static.flickr.com/2217/...5c0d194a7e.jpg
http://farm3.static.flickr.com/2180/...ff15116a45.jpg
Got the headers back from Jet-hot. Looks really nice. They did a nice job. They are coated Silver Sterling 1300.
OK, worked a little bit last night. Got the headers installed. The drivers side is a big PITA working around the brake lines. I should have listened to you guys and removed that heat shield. Getting that spark plug in there is a pain. The EGR tube didn't line up well so I'm just going to take it all off and cap it off. I'll leave the air pump lines capped off for now. I used Felpro gaskets and ARP SS bolts.
Pics :
http://farm4.static.flickr.com/3257/...605df1c1_o.jpg
http://farm3.static.flickr.com/2044/...69323f2a_o.jpg
http://farm4.static.flickr.com/3265/...2f1c2035_o.jpg
http://farm4.static.flickr.com/3041/...ba99f906_o.jpg
http://farm4.static.flickr.com/3243/...46483ba2_o.jpg
http://farm4.static.flickr.com/3224/...6e7e5fa6_o.jpg
Stock parts :
http://farm4.static.flickr.com/3261/...e1004e2e_o.jpg
http://farm4.static.flickr.com/3292/...0d586f2e_o.jpg
Got 3 parts Tig welded. This section of the exhaust will bolt inline to the Collector off the Y pipe. It just needs flanges welded on either end now. A Steel Fabricator Company called CT&S in Irving did it for me. I know the owner pretty well and he didn’t charge me to do it. Since the cut out is polished nice, Tig looks better than Mig. His welder, Robert did a good job.
http://farm4.static.flickr.com/3266/...05b89256_b.jpg
http://farm4.static.flickr.com/3097/...f382f7eb_b.jpg
http://farm4.static.flickr.com/3129/...4b1d19bc_b.jpg
I took these pics with my Blackjack II phone. Takes pretty good pics!
Almost done- just need to paint over all the welds with some VHT.
http://farm4.static.flickr.com/3103/...5a9aedc0_o.jpg
http://farm4.static.flickr.com/3292/...33808836_o.jpg
http://farm4.static.flickr.com/3155/...427eb2c0_o.jpg
http://farm4.static.flickr.com/3125/...043a5d08_o.jpg
http://farm4.static.flickr.com/3208/...2fdee765_o.jpg
http://farm4.static.flickr.com/3294/...5e0e73ce_o.jpg
http://farm4.static.flickr.com/3235/...8cca35ed_o.jpg
http://farm4.static.flickr.com/3289/...52fdbf14_o.jpg
http://farm4.static.flickr.com/3255/...76e662d0_o.jpg
http://farm4.static.flickr.com/3292/...cc26f8eb_o.jpg
http://farm4.static.flickr.com/3143/...41116654_o.jpg
http://farm4.static.flickr.com/3081/...c2311b33_o.jpg
__________________
1991 S10 5.7L TBI / 5 speed / 4:10 gears
2001 S10 Xtreme 4.3L / Auto ( The daily driver)
2002 Honda CBR 600 F4i ( SOLD )
1971 Ford Torino GT Convertible
My Links : #1 #2 #3
Beast S10 is offline   Reply With Quote
Old 08-20-2008, 02:08 PM   #2
Beast S10
Trader Rating: 0
2.25" Y Pipe, 3" from the Y pipe collector to the muffler, 2.25" dual exits to stainless tips.
__________________
My Links : #1 #2 #3
Old 08-20-2008, 02:33 PM   #3
A Low Dime
Trader Rating: 11
A Low Dime's Avatar
Send a message via AIM to A Low Dime
Looks good. I need to get my y-pipe built, the 1.75" stocker is terrible.
__________________
Brendan
2000 RCSB S10 4.3 8.7@77 1/8th236HP/311TQ --75 Shot
290?/390? 8.X?--Currently 125 Shot
A Low Dime is offline   Reply With Quote
Old 08-20-2008, 02:50 PM   #4
Beast S10
Trader Rating: 0
Quote:
Yeah they are horrible. I know a guy that can make you a really nice one from stainless - Mandrel built. PM me for his contact info. He helped me build all my exhaust.
__________________
My Links : #1 #2 #3
Old 08-21-2008, 07:55 PM   #5
Beast S10
Trader Rating: 0
Open Headers
Exhaust Rev
__________________
My Links : #1 #2 #3
Old 08-21-2008, 10:58 PM   #6
southern_chevy
Trader Rating: 5
southern_chevy's Avatar
looks great man.
__________________
2004 GMC ECSB Z-71 AEM Longtubes Modified with 3" Magnaflow, Intake, EFI Live, PLX Wideband, 206/212 .515/.522 112, stock heads milled .030", Patriot gold springs, comp pushrods, back to rockin the stock trans.
Demod sale: stall, E-cut out, nitrous kit PM for details
southern_chevy is offline   Reply With Quote
Old 09-04-2008, 09:48 AM   #7
Beast S10
Trader Rating: 0
http://farm4.static.flickr.com/3183/...24bafe5a_o.jpg
http://farm4.static.flickr.com/3202/...99c230ea_o.jpg
http://farm4.static.flickr.com/3194/...ef6fa438_o.jpg
http://farm4.static.flickr.com/3191/...9c3bf895_o.jpg
fresh VHT Paint. I used stainless pipe, but used a MIG. So some of the welds were rusting.
__________________
My Links : #1 #2 #3
Old 09-08-2008, 03:26 AM   #8
Beast S10
Trader Rating: 0
Worked on the drivers side header again. I was having some leaks. Shoddy braze welds around the Air injection tubes. I had a leak behind the heat shield too. One of the spot welds was loose. While I was at it, cut off the EGR tube. I had it capped off anyway. My steering shaft was melting on the heat shield too. I just removed that orange sleeve. I had the headers Jet hot coated, but messed it up by scratching them removing them again and welding, so I just touched them up with some VHT to hold me out until I can get them recoated. Having the heat shield off also gains better access to the spark plugs. Kinda looks ugly now with all the patches.
http://farm4.static.flickr.com/3123/...11fca31f_o.jpg
http://farm4.static.flickr.com/3287/...1075994b_o.jpg
http://farm4.static.flickr.com/3250/...8729ea6e_o.jpg
http://farm4.static.flickr.com/3170/...32830f7e_o.jpg
http://farm4.static.flickr.com/3035/...ae105c76_o.jpg
http://farm4.static.flickr.com/3225/...e8937a3a_o.jpg
__________________
My Links : #1 #2 #3
Old 10-27-2008, 10:21 AM   #9
Beast S10
Trader Rating: 0
Ok- New Magnaflow muffler installed. It's a 18" case, 3" inlet, 2.25" dual outlets, polished stainless steel. I know a guy that does exhaust work on the side in his garage and is a magnaflow dealer. I paid $130 for that muffler and he charged me $50 to install it, along with the tips. I chopped off the stainless tips I had on- they cracked and I had to have them reTigged. Then I polished them out to almost a mirror finish. Takes a lot of time to get them that way. I also pushed the tips back so they sit a little farther under the rollpan. I thought they stuck out too much before. I used BBQ 1200 degree paint to cover the welds. Its cheaper than VHT and does the job. I'll try to get a audio clip on how it sounds now. It's a lot quieter at idle vs the flowmaster I had on there. But when you get on it- it has a great tone and no drone. I would highly recommend this muffler for a daily driver.
Pics :
http://farm4.static.flickr.com/3060/...1f1351fa_o.jpg
http://farm4.static.flickr.com/3007/...6c231ee4_o.jpg
http://farm4.static.flickr.com/3244/...b54d9c29_o.jpg
http://farm4.static.flickr.com/3048/...ce1cf446_o.jpg
http://farm4.static.flickr.com/3208/...b52686f2_o.jpg
http://farm4.static.flickr.com/3238/...32af379d_o.jpg
__________________
My Links : #1 #2 #3
Old 10-27-2008, 02:52 PM   #10
Beast S10
Trader Rating: 0
I went by Autozone- to see what codes I was throwing. I think my O2s are bad... I started getting the codes after I installed the headers and new Y pipe. The Headers and collectors are Jet Hot Coated. The O2s sensors are still in the same location as the stock Y pipe had them. Attached are the codes. I have an aftermarket tune which deleted the 3rd O2 sensor after the cat. So I have just the main 2 on each side.
If you look hard you can see where the 02s are. Pics :
__________________
My Links : #1 #2 #3
Tags
43 , exhaust , s10 , xtreme
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Contact Us - PerformanceTrucks.net Forums - Archive - Top - Advertising - Privacy Policy - Terms of Use - Jobs
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
