4L60E to 4L80E Wiring Swap
Old 03-21-2008, 04:31 PM
  #21
8 Second Club
Flaco's Avatar
Originally Posted by DrX
Looks like it will be the same.
I wrote it up for quick reference:
Originally Posted by Derek @ EDO
Nice writeup, I made a .JPG copy for quick board reference.
cool writeup, thanks. This should be a sticky
Flaco is offline
Old 03-22-2008, 07:26 AM
  #22
FLT
FormerVendor
FLT's Avatar
+1 nice work. Calling Bill Reid we need a sticky!
FLT is offline
Old 04-16-2008, 09:22 AM
  #23
Bill Reid's Avatar
Done
Bill Reid is offline
Old 04-16-2008, 09:41 AM
  #24
Bill Reid's Avatar
... some more schematics...
4L60E Wiring...
4L80E Wiring...
Old 05-16-2008, 01:23 AM
  #25
hyeride00's Avatar
i sure cudda used this 4 years ago. i bit the bullet and bought the harness through speartech. Although they were extremely helpful and it got the job done at the time.....good job and good info gents
hyeride00 is offline
Old 08-14-2008, 12:03 AM
  #26
nonnieselman's Avatar
Glad i found this.... ahhahaha
https://ls1tech.com/forums/showthread.php?t=600178
nonnieselman is offline
Old 08-27-2008, 06:36 PM
  #27
Did you swap the pins at the trans end or did you do everything at the PCM end?
BTW...The PCM connectors are also Micropaks.
Looks like i missed a post...
I pulled the pins out of the Trans Connector and swapped them... really easy.
Old 08-27-2008, 10:04 PM
  #28
DrX
DrX's Avatar
Nice. No cutting or splicing required.
DrX is offline
Old 08-27-2008, 11:17 PM
  #29
Nope.. if you look at the Trans Connector you can see how you take it apart and seperate the parts..
Old 08-29-2008, 09:12 AM
  #30
Didnt see that any sponsor sells this kinda stuff so i hope this isnt against the rules..
Here are Some connectors that will help with 80E swap and other cool stuff...
VSS Sensor for the front of the 80E..
http://www.eficonnection.com/eficonn..._pigtails.aspx
Quick Reply: 4L60E to 4L80E Wiring Swap
