General Truck Racing and Discussion Baja, Stadium, Craftsman Truck Series, Offroad, Sleds, Mudding, Monster Trucks
Shift points
Old Apr 26, 2006 | 11:11 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Shift points
Where should my shift points be if my peak HP is @ 5800 and peak TQ @ 4700??
We did not adjust the shift points when I had the cam advanced so currently I am shifting at 6400 rpm.
How will this affect my 1/4? Should it be adjusted before I run again?
Old Apr 26, 2006 | 11:14 AM
TXsilverado's Avatar
seems like everyone always goes about 500 rpm over the peak to keep them in the powerband after the shift. i say do a street tune and use the butt dyno for whatever feels best. 6500 would be my wild guess.
Old Apr 26, 2006 | 12:05 PM
white1's Avatar
6100. You want to shift 300 past your peak power
Old Apr 26, 2006 | 12:08 PM
damn....im shifting 6200 on the stock cam....
Old Apr 26, 2006 | 01:09 PM
silver-mod-o's Avatar
Hunt&Fisherator
me too...
1-2@6200
2-3@6000
3-4@5900 (if I have enough pavement )
I am having the tr220 or 224 debate myself right now... maybe a custom grind for the nitrous...
Old Apr 26, 2006 | 01:58 PM
bluecajun5.3's Avatar
11 Second Truck Club
you need to figure out first what your shift extension are with the converter. (how many rpms drop after each shift.) base those rpms by going off of your dyno sheet. i only spin mine 6400.
Old Apr 26, 2006 | 02:06 PM
trever1t's Avatar
Yeah, i hear ya. I need someone with a video camera watching the gauges!
PS. love the new sig!
Old Apr 26, 2006 | 03:10 PM
Last Call's Avatar
TOTM: January 2007
Where is the dyno graph? I would make sure that the hp doesnt fall off significantly after 5800rpm. I dont think it would.
Keeping your truck in first gear for as long as possible is going to help you because of the huge transition in ratios bewteen 1st and 2nd gear. Also, the 6500 rpm redline may help you stay in 2nd gear through your whole run which would also make for a better time in the 1/4.
I would try 1 run shifting at 6000 manually. Your truck would probably shift at 62-6300 with the shift extension from the converter.
Wish I could go bro. Good luck!
Old Apr 26, 2006 | 03:53 PM
trever1t's Avatar
Shift points @ 6400, Red line is @ 6800 but i dont have an aux. tach so i only 'see' to 6000. I will try 1 run and hold 2nd. see if that helps. I cant see holding 1st gear past 6400 as it comes to quick.
Leaving work @ 2:30 so i should be there before 4:00!
MikeD.
Oct 13, 2015 08:08 AM
jtphelps289
Sep 29, 2015 12:00 PM
Lthompson
Sep 15, 2015 07:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
xerox17
Sep 5, 2015 01:23 PM
