Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > TRUCK PERFORMANCE & GROUP DISCUSSION > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Old 04-06-2006, 09:30 AM   #1
02BlueStepside
Trader Rating: 1
02BlueStepside's Avatar
Default Procharger Noise
Recently my procharger has started to make a new noise. It is not the constant whistle, more like a rattle for lack of words. I was checking out another forum and ran across this video of an 03/04 cobra with a Kenne Bell and it sounded similar to my procharger. Like I said, it sounds similar, but not nearly as loud.
Here's the video and you will hear it about half way through when they go to the under hood shot.
Click here to see Video
Anybody know what may be causing this sound? I don't know much, but I am assuming it needs rebuilt. Any help is appreciated.
02BlueStepside is offline   Reply With Quote
Old 04-06-2006, 10:43 AM   #2
Gmc²
Trader Rating: 1
Gmc²'s Avatar
Send a message via AIM to Gmc²
that guys car must have something seriously wrong, but i wouldnt think that it would be easy to compare a sound coming from a messed up twin screw to a messed up centri blower. geting it rebuilt couldnt hurt.
Gmc² is offline   Reply With Quote
Old 04-06-2006, 10:44 AM   #3
Gmc²
Trader Rating: 1
Gmc²'s Avatar
that was a nice car btw lol
Old 04-06-2006, 11:04 AM   #4
stripper
Trader Rating: 0
Have you checked the oil in your Porcharger? Just ruling out stuff.
stripper is offline   Reply With Quote
Old 04-06-2006, 11:40 AM   #5
02BlueStepside
Trader Rating: 1
I understand a twin screw and centri blower aren't the same, but the sound was similar.
I checked the oil a little while back, but I will go check again.
Old 04-06-2006, 12:59 PM   #6
Danville Performance
Trader Rating: 0
Danville Performance's Avatar
Send a message via AIM to Danville Performance
The noise is caused by irratic idle speed. The noise should be gone as soon as you bring it up to 900 rpm. At idle the motor pulsates(for lack of a better term) causing the impellers to jerk back and forth enough to make the noise. I did a 96 Cobra ATI Procharger kit and it made the same noise until we had the ECM reflashed and brought the idle speed up to about 800-900rpm so the motor was smoothier and the noise was gone. On the ati it is the gears rattling inside it from the irratic belt speeds at idle.
__________________
05 LLY Dmax DHRA 2 time National WInner Workstock sledpulling and 3rd in points for 07! 310hp/590ft
Danville Performance is offline   Reply With Quote
Old 04-06-2006, 01:28 PM   #7
02BlueStepside
Trader Rating: 1
I have had it on for 3-4 months now and it has just recently started this. It was a used unit if that makes a difference. Would putting a new belt possibly solve this? I don't know how old the kit/belt is and that would be the cheapest route. Also from the looks of it, I think I need two new idlers. Only thing I hate about that, its about $90 a piece for them.
Old 04-06-2006, 02:29 PM   #8
AintNoHo
Trader Rating: 0
AintNoHo's Avatar
It may only be what DanvillePerformance said but when the bearings went in my Vortech, thats also how it sounded. I would bypass the s/c pulley to be positive that's the source of the noise. Is it slightly oily around the bearings and getting worse? That's another indication of bearing wear. You wouldn't feel anything if you wiggle the pulley until it's way beyond worn. Make sure it has enough oil and isn't leaking and you're probably ok. Oh and make sure the pulley bolts haven't loosened and letting the pulleys move.
__________________
AintNoHo -Not an LS1 -Not a Radix
AintNoHo is offline   Reply With Quote
Old 04-06-2006, 10:41 PM   #9
fullthrottledan
Trader Rating: 2
Send a message via AIM to fullthrottledan
sounds like a bad bearing to me. best way to describe it is like there is rocks in there at idle
__________________
2000gmc rcsb 370ci, GT40-88, t56
fullthrottledan is offline   Reply With Quote
Old 04-07-2006, 03:24 PM   #10
Blown330
Trader Rating: 0
Blown330's Avatar
Doubtful it's the bearings...would be making much more racket if that was the case. It's either 2 things...gear backlash or cavitation. Backlash is mostly the case with a new head unit as it hasn't broken in yet...takes a few thousand miles really and then it quietens down. Cavitation is caused by air bubbles, for lack of a better description, and sounds like marbles rattling around. If it goes away with just a little bit of throttle then don't worry about it. Also check your belt tension....should be very tight.
__________________
2000 F-150 XLT, ProCharged
350/425...lot left in it.
Blown330 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Contact Us - PerformanceTrucks.net Forums - Archive - Top - Advertising - Privacy Policy - Terms of Use - Jobs
