Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
2003 sonoma 4.3L
Old Feb 24, 2006 | 12:03 AM
jdunnington's Avatar
Default 2003 sonoma 4.3L
hello i am new to this hole forum thing so if this is not exactly right im really sorry anyway i need help. ok i have a 2003 gmc sonoma 4.3l and i want to remove the cat but the 02 simulators (casper electronics) only go up to a 2002 and the guy there said its becuase gm changed there software on the new models so i would like to know if anyone else has just removed the cat and left the sensor or tried anything else becuase some people say that it doesnt hurt anything and others say that it will run rich and hurt the engine in the long run just would like to add headers and custom y pipe but want to get the straight answer about all of this oh yeah summit and jegs were no help any advise would be muchly appreciated thanks
Old Feb 24, 2006 | 11:27 AM
foff667's Avatar
LS1TECH Sponsor
you can also get it tuned out rather then buying o2 sims.
Old Feb 24, 2006 | 07:28 PM
eabigrick's Avatar
If You Had A Hemi You Wouldn't Have That Problem!!
Old Feb 26, 2006 | 10:12 AM
03NHSilvy's Avatar
Hemi-equipped trucks still have cats buddy
Old Feb 26, 2006 | 02:03 PM
eabigrick's Avatar
you dont know this one then do ya fella.........
Old Feb 26, 2006 | 04:07 PM
MikeZQ8SS's Avatar
Lets try to keep this one on topic guys....
One of the things you COULD do is chase part numbers for the stock 02 sensors on the 2002 and your 03. If the replacement 02 sensors are the same part number for both years, then I'd ASSUME you should be able to just order the 02 sims for the 2002 and use them on your 2003.
Old Feb 26, 2006 | 04:13 PM
MikeZQ8SS's Avatar
actually a quick search came up saying they're different part numbers.... maybe cross reference your stock 02 sensor part number, and see if it fits any different vehicles, then look for an 02 sim that fits the different vehicle? Sometimes a part will fit multiple vehicles but won't be listed for all of them... good luck.
Old Feb 26, 2006 | 05:09 PM
eabigrick's Avatar
he came across something on another forum were you screw the o2 sensor into a series of spark plug sheilds( for motors that use oil and foul plugs) and into the exhaust pipe to restrict the fumes to the sensor and trick it into seeing normal a/f readings. we have seen were people with everything from import cars to off road trucks have used this method and got very positive results.
Old Feb 27, 2006 | 11:24 AM
hellbents10's Avatar
LS1Tech Sponsor
If you want to make your truck faster why not just get it tunned, then tune out the rear 02. Does not cost that much for the gains you get across the board.
Old Mar 3, 2006 | 12:48 AM
eabigrick's Avatar
every day at work i try to talk him into a custom tune, but he is not ready to spend the money to get it tuned. it really is the way to go no matter what you drive. anybody with the right software can double the performance gains or even more than that over any handheld.
calsdad
Jun 14, 2023 11:07 PM
SloSVO
Nov 22, 2020 07:34 PM
twake_410
Apr 14, 2016 09:58 PM
Raiderjim
14
Sep 26, 2015 10:18 PM
