Drivetrain & Suspension Transmission | Gearing | Traction
PWM trans swap to Non-PWM trans?????
Old Dec 24, 2005 | 01:28 AM
350SS's Avatar
Default PWM trans swap to Non-PWM trans?????
Just wondering if there is a simple answer to this question. I have a 98 Chevy truck so the trans uses TC PWM. I have Hughes pre-PWM trans and converter that I would like to install if the stock one ever takes a crap. Can this trans even be used in my truck or will this set a code without the PWM? I have a transgo shift kit in the truck but can't recall if this eliminated this function (it's been a few years). I think it did because at the time I did the shift kit to get rid of the problem of it slipping out of TC lockup in 4th under light throttle, which it did. Additionally, the Hughes trans that I have is an electronic valve body style but without the bolt on bellhousing like the 98 trans has. Is there any reason why I can't use this trans on my 98?
Mad Max
Old Dec 29, 2005 | 11:18 PM
350SS's Avatar
Default James B.
James, I know you're out there!
Old Dec 29, 2005 | 11:22 PM
350SS's Avatar
Default Oops....wrong forum
Bumpers
Aug 4, 2024 09:44 PM
1slwgto
Aug 16, 2015 06:40 PM
CammedZ71
Aug 2, 2015 01:44 AM
alex226
Jul 27, 2015 07:12 AM
davis28905
Jul 8, 2015 03:20 AM
