Drivetrain & Suspension Transmission | Gearing | Traction
Wiring up 80-e VSS...where do the wires go?
Old Oct 31, 2005 | 06:28 PM
Scream's Avatar
MOOBIES Moderator
Default Wiring up 80-e VSS...where do the wires go?
I thought that Speartech included a diagram with the harness, but they didn't. Can anyone hook me up w/ some info on how to hook this new VSS up?
Old Oct 31, 2005 | 06:54 PM
quicksilverado's Avatar
Give them a ring in the morning. When I got mine I called them and they told me what to do. I can't remember or I would help.
Old Oct 31, 2005 | 08:11 PM
Flyer's Avatar
There are 2 new wires, I can't remember off hand what pins they go to in the PCM, but that's where they go. The bigger piece is just a converter more or less.
Some searching should tell you the pin numbers for the VSS sensor.
Old Oct 31, 2005 | 08:23 PM
Scream's Avatar
MOOBIES Moderator
Yeah, I posted this in the wrong forum. Way to go moderator! I've got a HUGE headache that just won't quit.
I'll do some more searching, but I didn't understand the posts that I found. I'll look again when my head isn't splitting.
Old Oct 31, 2005 | 08:54 PM
XLR8NSS's Avatar
Adkoonerstrator
Crap, I don't remember what pins those two wires went in.
Old Oct 31, 2005 | 09:35 PM
On the red pcm connector, red wire goes to pin 22 and blue wire to pin 23.
Old Nov 1, 2005 | 07:37 AM
Scream's Avatar
MOOBIES Moderator
Are the pins on the PCM connector numbered? I thought you had to tap into the harness, not the PCM?
Old Nov 1, 2005 | 07:54 AM
They are numbered.
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
