Fuel Pump
Old Oct 6, 2005 | 10:47 AM
Default Fuel Pump
Will the stock fuel pump hold my setup and a 150 shot of wet nos or do i need to upgrade my pump. I will also run a couple of 200 shot runs. any help would be apreciated.
Old Oct 6, 2005 | 12:26 PM
Fogle07's Avatar
might as well go ahead and upgrade the pump. they are cheap enough just for insurance
Old Oct 6, 2005 | 03:31 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yeah you need a new pump 175 is about the limit on a 5.3 so with your setup and that big of a shot you need the pump.
Old Oct 6, 2005 | 03:33 PM
which would be better an inline fuel pump or just install abigger pump in the tank?
Old Oct 6, 2005 | 03:39 PM
Fogle07's Avatar
get an intake fuel pump. pm blownchevy he can help you with one
Old Oct 6, 2005 | 03:47 PM
could this also be why when i get around 1/8 tank my truck starts to cut out bad at wot
Old Oct 6, 2005 | 04:01 PM
1slow01Z71's Avatar
They dont make an in-tank one for our body style 03 and up you can get the walbro in-tank setup. You have to get an inline one. Speed Inc has a 255lph kit. Should do the trick. I dont have that problem that you are tlaking about even when I was spraying a 100 shot out of the hole with the low fuel light on.
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
