99 Pcm
Old Jul 20, 2005 | 10:10 PM
z7199's Avatar
Default 99 Pcm
I have a 99 NBS Z71 I have heard all the wonderfull things Nelson can do for our trucks. Also I have heard about all the wondrfull things a 02 PCM can do for my truck. I was just wondering why does the 02 make such a difference when they both get tuned. and should I do the 02 swap is there alot invloed or just keep the 99 and get it tunued?
Old Jul 20, 2005 | 11:09 PM
the 99 and 00 have false knock readings in them the 01 02 do not. When the pcm sees knock it retards timming. It would be best just to get an 01,02 programed.
Old Jul 20, 2005 | 11:19 PM
z7199's Avatar
Is that the only thing that is wrong with them or is there other things?
Old Jul 21, 2005 | 06:52 AM
All that I know of.
Old Jul 21, 2005 | 12:34 PM
Zick's Avatar
Didn't the 02' have a better timing table, thought I heard that somewhere.
Old Jul 21, 2005 | 07:26 PM
z7199's Avatar
Also where would I go about getting one? Junk YArd?
Old Jul 21, 2005 | 07:35 PM
I got my 02 PCM right from PCMforLess when I got it tuned...junkyards around here don't seem to have any new stuff. Whichever tuner you decide to go with should be able to hook you up.
I think you're right Zick, the base timing tables of the 01-02 PCM's are better than the 99-00's. I remember reading here that the newer PCM's have a different operating system and more memory also.
Don't forget that the 99's have smaller injectors than all the other years (21lbs vs 24lbs), and it's a good idea to upgrade them if going with the newer PCM. Any 00 and up 4.8-6.0 fuel injector will work (well, not sure about flex-fuel but any gas injector will work)
Old Jul 21, 2005 | 10:37 PM
I know it would be a good thing to upgrade them but would it hurt to run the 02 ecm with the stock 99 injectors? Would I see any lean conditions?
Old Jul 22, 2005 | 12:58 PM
Honestly, I'm not sure. I would think it would since the 02 PCM is programmed to duty cycle less for the slightly larger injectors, but then again, theoretically, the PCM should pick up on the lean condition and compensate. FWIW, I went the other direction and swapped injectors before PCM's, and didn't experience any problems that I know of (although I didn't have a scan tool to check my a/f ratio). Check the classified section here, I noticed some folks selling some injectors for about $60.
Old Jul 25, 2005 | 03:51 PM
z7199's Avatar
will do thanks guys!!!!!
Wrecker 426
Sep 30, 2015 09:39 PM
Velocity1
Sep 22, 2015 01:32 PM
kalikid06
Sep 20, 2015 07:46 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
