Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > Tuning & Diagnostics
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Performance Trucks!
Welcome to Performance Trucks,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Old 12-19-2008, 06:38 AM   #1
TURBHOE
Trader Rating: 3
12 Second Truck Club
TURBHOE's Avatar
Default 4.3l marine intake tuning
does anybody know the fuel injectors size and fuel pressure of the 4.3l marine intake manifold. i found 28.4 ish and 58-60psi like ours but i want to be sure.
__________________
'04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, SC3200 yank, FLT LVL 7 4L60E, 5.3L, ls6 heads, lsg cam. 12.33 @110mph
http://www.streetfire.net/video/turb...mph_741849.htm
4.3l budget build http://performancetrucks.net/forums/...d.php?t=442854
TURBHOE is offline   Reply With Quote
Old 12-23-2008, 11:53 AM   #2
hog
Trader Rating: 0
Send a message via AIM to hog
I have a 5.7 mercruiser marine intake on my truck right now. I am using the marine MULTEC 2 EV6 connector injectors. I had them flow tested and they flow around 24 #/hr at 43.5psi 3 BAR of fuel pressure.
The marine FPR regulates teh rail pressure to 58 psi or 4BAR of fuel pressure. At this pressure they flow 27.2 lb/hr according to the Weiss fuel injetor calculator.(or 28.2 lb/hr at 60 psi)
peace
Hog
__________________
1997 GMC C1500 rcsb L31 5.7 4050 lb 1999 4l60e, V6 S-10 verter, 3.42 G80, Hooker LT's 1 5/8" 2 1/2", dual 2-1/2" cats, 4" B4 tire side exit exh. K&N FIPK, GM/Mercruiser Vortec marine intake manifold(iron lower aluminum upper), EV6 29 lb injectors@60 psi, marine fuel rails, vacuum ref. FPR, modified Ed Wright PCM by me, LT4 KM
1/4 mile stats(bests)
Stock-15.9@82mph 2.490 60ft
Mods-14.8@94mph 2.007 60ft(b4 TC&intake)
hog is offline   Reply With Quote
Old 12-23-2008, 02:36 PM   #3
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
thank you, i finally found some info online, and this helps to confirm what i found.
__________________
Old 01-06-2009, 07:22 PM   #4
A Low Dime
Trader Rating: 13
A Low Dime's Avatar
Send a message via AIM to A Low Dime
So far how is this intake working out for you? I just ordered mine today, I will be installing it in a few week, probably early Febuary.
__________________
Brendan
Just Installed 224/230 112 Custom Grind-K/N FIPK-Marine Intake Manifold Swap
P/P LS1 TB-NX Kit-LS1 Electric Fans-Upgraded Y Pipe-Tuned-Built Trans-Shift Kit-Stock Converter
3.73's-Zexel Torsion Unit-Coddington 17's-275/40/17 Nitto 555r's
A Low Dime is offline   Reply With Quote
Old 01-06-2009, 08:53 PM   #5
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
not so good truck runs like ass. but its not caused by the intake. but maybe the injectors it came with. most new injectors come encased in oil. these were dry and already installed for no telling how long. so i think some may be faulty. not sure just yet if its spark or fuel but there is a multiple misfire somewhere.
__________________
Old 01-07-2009, 08:51 AM   #6
hog
Trader Rating: 0
I have found that the marine intake regulator works quite a bit differently than teh stock L31/35 poppets spider regulator.
The stock FPR would have fuel pressure up around 66 psi, with a low of around 56 psi, of course depending on vacuum.
the marine FPR has a high of 58 psi and a low of 50 psi.
When I did my V8 marine intake swap I had the injector harness swapped bank to bank causing split BLM's, I diagnosed it with an injector balance test.
A simple balance test should tell you if your injectors are good.
You cycle the fuel pump with the key, then the scan tool cycles 1 single injector, then you record just how much the fuel rail pressure drops. Then you recycle teh key, bringing the rail pressure up, then you do the enext injector, then record the fuel rail pressure drop.
the cylinder with the least pressure drop, or no pressure drop is a weak/clogged injector.
This test told me that I was energizing injectors 2,4,6,8, when I was commanding 1,3,5,7.
I hope you get it figured out.
peace
Hog
__________________
Old 01-07-2009, 11:24 AM   #7
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
which scan tool? the orange ones like auto zone has or the tech II? i tore the old manifold apart to see which injector went where. but i could be wrong I'll see if i can find a write up with wiring to make sure its right. i tried to use hp tuners balance injector thing but its only good for v8's it seems. i can get a fuel pressure gauge from a buddy.
right now after idling for a few minutes you can touch the manifold right where it comes off the head. some ports are hot as hell a couple are just warm to the touch.
here is a question. if i pull the plugs on the cold ports, what would they look like if no fuel but good spark good fuel no spark?
__________________
Old 01-07-2009, 11:52 AM   #8
dc_justin
Trader Rating: 13
Hello Dave
dc_justin's Avatar
peace
Hog
Not meaning to be nit-picky, but it they flow 27.2 at 58psi, they'd flow 27.7 at 60psi (sqrt(60/58) x 27.2)
__________________
http://www.blackbearperformance.com/images/bbp_sig.jpg
Black Bear Performance - Custom Tuning Solutions
08 TBSS - TVS 1900
03 SSS - L92 heads, TVS 2300
02 M6 WS6
dc_justin is offline   Reply With Quote
Old 01-07-2009, 10:02 PM   #9
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
well i had 27.8 in there anyway.
__________________
Old 01-11-2009, 09:22 PM   #10
hog
Trader Rating: 0
Quote:
No, no, thats cool, you kinda have to be picky with IFR's.
I was simply using Stan Weiss's online IFR calc.
OLD pressure=43.5
new press=58
injector size 24 pph
I get 27.7
old press 43.5
new press. 60
injector size 24pph
28.1pph
Sorry, I musta entered an incorrect digit. Thanks Justin.
peace
Hog
__________________
Tags
43 , 43l , fuel , intake , low , manifold , marine , merc , mpfi , pressure , psi , s10 , stalls , swap , vortec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Contact Us - PerformanceTrucks.net Forums - Archive -
Top - Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
