Removing luggage rack on '97 tahoe - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 02-03-2004, 03:47 PM   #1
Default Removing luggage rack on '97 tahoe
I want to remove the luggage rack on my tahoe. I know that the outer part comes off with just torx screws, but what do I fill the holes with and how do I get the center part off.
Thanks
bdubc is offline   Reply With Quote
Old 02-04-2004, 04:20 AM   #2
You would have to get them shaved just like any other part on the truck, they fill the hole, smooth it out and repaint.
LOW2000 is offline   Reply With Quote
Old 02-04-2004, 09:52 AM   #3
I have seen it where you just pop in little rubber or plastic fillers, and that is the end of it. Perhaps you have to silicone them in but it is a lot less of a pain in the *** than shaving. I was just curious if you guys knew where i could get those fillers.
Old 02-04-2004, 12:42 PM   #4
done that numerous times
Any parts store - or autobody supply
I siliconed them in
Basicaly it is a body,fender plug or fastener.
Better than shaving and painting the roof.
LS1csherm is offline   Reply With Quote
Old 02-04-2004, 01:00 PM   #5
Quote:
Better...no...cheaper...yes
Old 02-04-2004, 02:39 PM   #6
What about the center pieces of the roof rack??
Old 02-04-2004, 05:48 PM   #7
Quote:
They are adhesive backed. - Peel off and clean the sheetmetal
Old 02-04-2004, 05:54 PM   #8
Quote:
My opinion it is better - no welding - dont have to drop the headliner - no filler - no sanding - dont have to paint and clear the roof - retain the factory paint and the rack can be put back on if needed.
Better as far as custom looking - no - nothing better than a good shave
Just have to go for what pleases you and the look your going for.
Old 02-04-2004, 06:53 PM   #9
LS1Tech Co-Founder
Pro Stock John's Avatar
My police issue 1999 Tahoe did not come with a roof rack:
www.ls1tech.com/99Tahoe/xcar8.jpg
Pro Stock John is offline   Reply With Quote
Old 02-05-2004, 02:34 PM   #10
Can I take the Chrome trim on the fenders off just like the trim on the doors on the tahoe?? Does it just come off with heat??
Thread Thread Starter Forum Replies Last Post
Picked up a new Ride... cheyenne383 GMT 800 & Older GM General Discussion 9 11-13-2015 10:24 AM
New Exhaust and some info 03sierraslt GM Engine & Exhaust Performance 14 10-09-2015 06:53 AM
Truck making wierd... sounds? Infernohoe GM Engine & Exhaust Performance 48 10-02-2015 11:25 PM
2001 Camaro SS Turbo 4.8 97_ek Cars and Motorcycle Classifieds 0 09-23-2015 10:16 PM
Removing 4L80E and Transfer Case on 2001 2500HD 69z-28 GM Drivetrain & Suspension 17 09-21-2015 08:31 AM
Tags
09, 1999, 97, back, carrier, chevrolet, holes, luggage, plug, rack, remove, removing, roof, shaved, tahoe
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
