OEM wheel weights
Old 03-03-2015, 02:28 PM
High on diesel fumes
thunder550's Avatar
Anyone know how much these 18's weigh?
Or the Nissan Titan 18's?
Old 03-03-2015, 02:58 PM
thunder550's Avatar
Found a couple different places that put the Titan 18 at ~ 30 lbs. Curious about the split 5 spoke Chevy wheels above, those look nice.
Great part about the 18's is I could run a 285/60R18 Proxes S/T 2 (Nitto's widest 420 in a 18" wheel is 255), keep about the same diameter, pick up a little section width, pick up a little sidewall height, and still drop somewhere around 15 lbs per corner depending on how much the wheels weigh.
Old 03-03-2015, 03:53 PM
thunder550's Avatar
30 lbs each for the split 5 spokes too, according to a friend who works at a Chevy dealer.
Old 03-03-2015, 05:05 PM
skolman91's Avatar
I would call that an all around win, until you throw them on and still not like them or they rub..
Old 03-03-2015, 08:09 PM
thunder550's Avatar
Got some more info from my buddy.
Tahoe 20 LTZ wheels are 39 lbs. Toyo Proxes S/T in 275/55R20 are 41 lbs. I'm currently at 80 lbs each.
14/15 Silverado 18's are 30 lbs each. Toyo Proxes S/T2 in 285/60R18 are 40 lbs. I'd be at 70 lbs each. (10 lb drop per wheel)
I also found Enkei ST6 on Tirerack that shows 25 lbs each. With the same S/T2 at 40 lbs I'd be at 65 lbs each. (15 lb drop per wheel)
The Enkie's would run me about what I could buy a set of OEM 18 takeoff wheel/tire package for, and after selling the tires I'd probably be $200-$300 cheaper for the OEM. I like the OEM look better and they are cheaper. I just wonder how much of a difference the extra 5 lbs each would make.
Old 04-30-2015, 07:01 PM
KC_kid's Avatar
Did this ever go anywhere?? I need new tires on my chrome clad 20s that weight 76lbs each corner. I'm thinking of going to a 17" or 18" wheel when I buy tires, but trying to "weigh" the benefits. I'm looking for mpg and seat of the pants gains specifically
Old 04-30-2015, 07:50 PM
GMCtrk's Avatar
Given similar tire diameters to exclude gearing effect, I doubt you'll notice any difference.
i've downsized wheels before expecting mileage gains but they were not realized.
Old 04-30-2015, 08:19 PM
KC_kid's Avatar
Thanks, I appreciate the feedback
Old 05-01-2015, 09:21 PM
thunder550's Avatar
I decided to keep my 20's. Just put a new set of Nitto 420S on them today as a matter of fact
Go5.3tt06
25
09-04-2016 10:25 AM
mikeyjm1
17
10-29-2015 11:04 PM
chvy=power
09-08-2015 11:06 AM
Sdailey
09-06-2015 10:26 PM
the owl
09-04-2015 04:09 PM
Quick Reply: OEM wheel weights
