another lighting kill
lolwut.
Why in the world would you spend (waste) all the time and money building a 60E, when a junker 80E w/ shift kit would hold up better? I've got a built 60E in my 3200 lb. truck, and I'm afraid that the thing is starting to give. 80E, and no worries. Set it and forget it.
Hmm ok...
4l60e
1st-3.059:1
2nd-1.625:1
3rd-1.000:1
4th-0.696:1
4l80e
1st 2.482:1
2nd 1.482:1
3rd 1.000:1
4th 0.750:1
Not a great option behind a cam only street truck, imo. Especially with a 5.3. My 60e is holding up great behind my cammed 6.0. Other builds on this site with 4l60e's putting A LOT more power to the ground than my truck is. Like I said, find a good builder.
4l60e
1st-3.059:1
2nd-1.625:1
3rd-1.000:1
4th-0.696:1
4l80e
1st 2.482:1
2nd 1.482:1
3rd 1.000:1
4th 0.750:1
I have a pretty decent builder local. He has built a 4l60 for me that was great, but it was just behind a bolt on 5.3. He also built a 4l70 behind a cam and sprayed tbss my buddy had and it held up well. Hes a real honest guy.
Although, its about 1800 for a 4l60 from him then add another 400 on for a converter. A 4l80 is about 600 here then add 800 for a converter. The 4l80 is more budget friendly.
It seems everyones concerns about a 4l80 is the first gear ratio. That is very understandable. I think the closer gear ratios, and less split between the gears, is a benefit though.
Im up in the air on it still. My goal is 400 - 450 rwhp on the juice and i BEAT on my truck as well. Id just rather spend the money right the first time. So, everyones opinions are welcome.
Running a shorter gear ratio would help. But then, unless you do the work yourself, you are adding a lot more to your budget.
Id definitely go with a 80 if I had a boosted engine or a maybe a 400+ cu in. stroker. I'm sticking with my 60, for what I want.
Ive got a baby cam only LQ4 and a stock 80E.. love it
I wouldnt have it any other way.
Unless you have actually drive the same truck with a 60E and then with the 80E, the gear ratio thing is all speculation with numbers that dont look right.
I wouldnt waste money on a 60E, but thats just me. Ive learned my lesson and that wont happen again.
Did you happen to notice the relatively large cam in the lm7? You want to put a 4l80e behind that? Are you ******* retarded? Nobody said there was a problem with how they drove. I think its going to slow his truck down. And that was and is my entire point.
Bullshit ratios, I like that. Good post dood
It's not hard to build a 60e to handle what he's putting down, power wise.
The **** do you know about what I've driven? Why don't you calm down and realize this is just an internet discussion.
