TVS 2300 + other Goodies in an '04 SSS
The time has finally come after completing a 4L80e swap a few months ago! These stages of my build will include...
STAGE 1:
1. Magnuson TVS 2300 - non-Jackshaft model This is the complete kit ordered directly from Magnuson - On Order
2. ARH 1-7/8" Primaries and connecting pipes w/no cats - On Order
3. TYC E-Fans and wiring harness - On order
4. Tru-cool max trans cooler with bypass valve - Have now but not installed
5. Upgraded Alternator - 145 amp. - On order
6. Aeroforce Interceptor Gauges and A-Pillar Pod
I'll have to wait and see exactly what the blower kit from Magnuson comes with, but the guy I ordered it from said it came with 42lb injectors and I think I may need a charge tube to connect to my Volant CAI box. I'm not sure if I would need anything else, but I really wanted to install the kit just as if comes from Magnuson to make sure there are no problems with the blower system before I start adding. Not sure if I need a TB or x-link for this part either.
STAGE 2:
1. Intro Twisted Vista II 22" x 10" - I'm told +30 offset and a good set of tires - I'm told 305/40/22's will work here
2. Speedsturr Tonneau cover
STAGE 3:
1. Trickflow 235 heads and springs
2. Chromoly Push Rods
3. Harland Sharp Rockers
4. Possibly Lifters - would like suggestions here please
5. 60lb Siemens Deka Injectors
6. Fuel Pump? - open to suggestions
7. 90 or 102mm TB and x-link? - open to suggestions
8. Custom grind Cam
9. ARP bolts
10. Valve covers - open to suggestions
11. 8 rib system
12. Trutrac rear and Trickflow cover
...and anything else I'm forgetting to make this setup work!
STAGE 1:
STAGE 2:
STAGE 3:
8. Custom grind Cam
9. ARP bolts
11. 8 rib system
Yeah, I found a descent deal on Amazon for an AC Delco 145 amp. and got that and some TYC fans ordered yesterday. That gauge setup looks good there btw.
You're gonna want to add more gauges than just the aeroforce... those wont tell you what you really need to know. Wideband, fuel pressure, and boost gauges are most important.
I thought you already had the headers for some reason?
Good lookin list of mods though... its gonna move. When is the blower going on?
Prosport 238EVOBO-PK 60mm Premium Evo Electrical Boost Gauge
Yes, I do have headers now, but they're only 1-3/4"...upgrading to ARH 1-7/8"
I spoke to the dude from Magnuson last week and he told me it would ship out on or before this Friday the 30th. I'll probably do the install the following week - depending on exactly when I receive it. All the other parts are due in this week.
