turbo ls1 s10 ( yes another s10)
so i got started and pulled the motor back out after mock up to drill and tap oil pan
engine bay getten washed off too
since i had only single exhaust i moved the trans cooler to d/s and added a fan
i made some cooler lines out 3/8 alum fuel line i had
i mounted the trans temp above trans with brass fittings. hint make sure you bring a ground wire to sender if you relocate it. ask me how i know
i made line for turbo -4 off sender
is that with a cam,built tranny,bigger built rearend plus the cost of the truck right?It is because I am thinking of starting one but a slower process because of small funds.
