Tuner Question - Drive-by-wire
I will also post this in the Tuner section.
My project I plan to install a 2014 and up LV3 4.3lt in this.
But I will have to splice into the drive-by-wire accelerator harness to make it long enough.
Passenger front view of Ultravan #231. Also know as Uv231 Project. Plans to install an LV3 4.3lt, 6L80e 6 speed Auto with paddle shifting in the back under the bed.
Tuner Question about Drive-by wire...
Is there a way in the HP tuner setup to make adjustments should the readings change - due to the type and length of wire needed to make the drive-by-wire long enough to work in the above vehicle?
Thank you,
Thank you,
