NNBS denali 6.2L dropped and blown build pics
#22
Nope! 6 packs 12 packs 18 packs and 30 packs.
Our percentage of alcohol is also higher by volume too.
I think the 15 pack is like around $40 up there where as its only 1/2 that in the states.
I know Canada taxes alcohol and cigarettes heavily up there to pay for the free health care.
Chew is like $20 up there and in some states down here it's only $2.50, in others it as much as $5.00, Same with cigarettes. you also have a bunch of tax and warning stickers on them that we don't have.
fuel, tobacco and alcohol are so much cheaper.
#23
Okay bit of an update here, got my trans cooler and stuff and got around to installing it.
Heres what got dropped off.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%2011ffdg_zpsaib8vxxi.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%2011ffdg_zpsaib8vxxi.jpg" border="0" alt=" photo image1 11ffdg_zpsaib8vxxi.jpg"/></a>
Tru cool 40k
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%209ii_zpssxozne8a.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%209ii_zpssxozne8a.jpg" border="0" alt=" photo image2 9ii_zpssxozne8a.jpg"/></a>
Handful of fittings and some -6 hose
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%209hjgf_zpshqrwx0rk.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%209hjgf_zpshqrwx0rk.jpg" border="0" alt=" photo image2 9hjgf_zpshqrwx0rk.jpg"/></a>
Also picked up some 7" fans
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%2011jjjjj_zpspohqr5c2.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%2011jjjjj_zpspohqr5c2.jpg" border="0" alt=" photo image1 11jjjjj_zpspohqr5c2.jpg"/></a>
Tru cool 40k
#24
picked up some aluminum flat stock and some stainless fasteners and started by mounting up the fans. I know its overkill, but even with the stock cooler the trans never got really hot unless sitting in traffic. so I added the fans to control temps better when there is no air flow.
<a href="http://s1352.photobucket.com/user/jroctpb/media/ghjhgjghjh_zpsdmqx2bly.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/ghjhgjghjh_zpsdmqx2bly.jpg" border="0" alt=" photo ghjhgjghjh_zpsdmqx2bly.jpg"/></a>
the flat sections on either side sit on the frame rails and are fastened to the frame by self tapping stainless screws. Also deburred and radiused all the edges and corners on the brackets.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%2011ghjghjgf_zpshrgqi1qy.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%2011ghjghjgf_zpshrgqi1qy.jpg" border="0" alt=" photo image1 11ghjghjgf_zpshrgqi1qy.jpg"/></a>
then I made some brackets for the lower mounts. These attached to the factory splash guard bolts up front.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%2011hh_zpsuomf0bow.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%2011hh_zpsuomf0bow.jpg" border="0" alt=" photo image1 11hh_zpsuomf0bow.jpg"/></a>
#25
Mocked it up, placed it to utilize the lower bumper grill since there is no room up top with the heat exchanger. Plus its just wasted space down there.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%2011nnn_zpsdus9hrpl.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%2011nnn_zpsdus9hrpl.jpg" border="0" alt=" photo image1 11nnn_zpsdus9hrpl.jpg"/></a>
here is where the lower mounts piggy back off the splash guard mounts. I can wiggle the whole truck back and forth grabbing these and the cooler stays rigid. Pretty good I think considering the whole bracket assembly weighs less then 2 pounds.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%208jj_zpsmlnf8ddd.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%208jj_zpsmlnf8ddd.jpg" border="0" alt=" photo image2 8jj_zpsmlnf8ddd.jpg"/></a>
#26
punched a hole through the top bracket for the wires.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%208hhy_zps3y2dkv3f.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%208hhy_zps3y2dkv3f.jpg" border="0" alt=" photo image2 8hhy_zps3y2dkv3f.jpg"/></a>
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%209222_zpsfbuwbhtk.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%209222_zpsfbuwbhtk.jpg" border="0" alt=" photo image2 9222_zpsfbuwbhtk.jpg"/></a>
#27
assembled some new trans cooler lines using russels -6 hose and fittings. I will be using the factory in rad pre cooler for this.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%201hg1_zpsdh5h0v3t.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%201hg1_zpsdh5h0v3t.jpg" border="0" alt=" photo image1 1hg1_zpsdh5h0v3t.jpg"/></a>
Got some 5/8 flare to -6 fittings for the rad side cause thats what the trucool install thread said was needed. They did not work for my rad, i dont know if all nnbs trucks are like this but they didnt fit.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%201154542g_zpswe7tzjqe.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%201154542g_zpswe7tzjqe.jpg" border="0" alt=" photo image1 1154542g_zpswe7tzjqe.jpg"/></a>
purchased a bunch more fittings but none worked so i ended up using 3/8 to -6 compression fittings.
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%20111_zpsfr5selcd.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%20111_zpsfr5selcd.jpg" border="0" alt=" photo image1 111_zpsfr5selcd.jpg"/></a>
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%208_zpshzrmpni6.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%208_zpshzrmpni6.jpg" border="0" alt=" photo image2 8_zpshzrmpni6.jpg"/></a>
#28
Comparison with stock cooler
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%208t_zpsz414jux0.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%208t_zpsz414jux0.jpg" border="0" alt=" photo image2 8t_zpsz414jux0.jpg"/></a>
cooler in place
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1_zpsz5f02cr0.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1_zpsz5f02cr0.jpg" border="0" alt=" photo image1_zpsz5f02cr0.jpg"/></a>
Purchased this to convert the 6l80 to -6 AN
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%2017771_zpshinmdg7s.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%2017771_zpshinmdg7s.jpg" border="0" alt=" photo image1 17771_zpshinmdg7s.jpg"/></a>
<a href="http://s1352.photobucket.com/user/jroctpb/media/image1%2011_zpsr7zvxban.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image1%2011_zpsr7zvxban.jpg" border="0" alt=" photo image1 11_zpsr7zvxban.jpg"/></a>
cooler in place
#29
Rest of the plumbing...
Cooler
<a href="http://s1352.photobucket.com/user/jroctpb/media/image2%209bbb_zpswl4jlrk1.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/image2%209bbb_zpswl4jlrk1.jpg" border="0" alt=" photo image2 9bbb_zpswl4jlrk1.jpg"/></a>
Rad side
<a href="http://s1352.photobucket.com/user/jroctpb/media/gfgfgfgggf_zpsxi7rz4nw.jpg.html" target="_blank"><img src="http://i1352.photobucket.com/albums/q656/jroctpb/gfgfgfgggf_zpsxi7rz4nw.jpg" border="0" alt=" photo gfgfgfgggf_zpsxi7rz4nw.jpg"/></a>
Tested for leaks today and its all good! just have to wire up the fans and then it will be good to go. higher stall speed to come!
Cooler
Rad side
