Am I too late for an LT1 swap?
Old 11-28-2010, 10:06 PM
HotLines's Avatar
Default Am I too late for an LT1 swap?
I have an unmolested stock 1990 Silverado 350 with a 5 speed manual and also have a 96 LT1 with a BW T56 6 speed with computer, wiring, gas tank and everything else I believe is needed. I live in southern Oregon where whenever I ask a question, I get no answers. Can anyone explain what kind of swap this is, easy or hard and what exactly may be needed. I'm an ol'man but I believe I could do this if I had some help or helped someone else, if need be. If it comes down to just swapping the 6 speed, it would put a little smile on my face but not entirely
What should I do? Thanks in advance
Old 11-28-2010, 10:11 PM
Baltimore Whore
Mangled03gmc's Avatar
If you have the harness it should be easy to do.. I think from 93-96 they used opti spark ignition system.. Yours is opti spark?? Everything should be a direct bolt in. Mounts are all the same.. You will have to add electric fans.. The trans will just be some fabbing, brackets, console for the floor, the addition of getting the drive shaft redone to fit..
Old 11-28-2010, 10:20 PM
HotLines's Avatar
yes, its an opti-spark, here is a photo of the engine and trans.
XL7
05-05-2022 01:48 PM
Bluecollar Hotrods
03-13-2017 05:02 PM
GrooveCityZ71
08-31-2015 12:05 PM
superchomper2003
08-26-2015 09:39 AM
WICK3DxGATA
07-21-2015 06:59 PM
Quick Reply: Am I too late for an LT1 swap?
