Jake's '05 Rcsb s488 4l80 build
#141
I dont have an issue with the bolts with them separated, i am just trying to conserve time, i am doing the swap at work(after work hours) and cant tie the rack up and i would need to be able to push it in and out if need be, seriosuly thinking a weekend would be best, but that means giving up time with my kids... Wishing i had bought a house with a garage!!!
#143
8 Second Truck Club
Man, really you need to get the truck together to figure out if that yolk is gonna work. I'm gonna say it is too long. There are at lease 3 different length yolks for a th400 style output shaft (same as 4l80e I believe). Once you get the truck together you need to make sure that you have enough pull out with the driveshaft bolted in, other wise you will be destroying thrust bearings in the motor on the regular.
#144
Well...today at work i was checking out atomic hydro boost swap and decided i was gonna do mine. I ordered the hydro booster from lkq for 35 bucks! When i got home i pulled the vacuum booster and the brake pedal. It took maybe 15 mins! Hopefully the swap goes that smooth. I also got the frame mounts put in and torqued, so I'm ready to drop the motor and trans in. Maybe tomorrow then ill be able to check the driveshaft and yoke
#146
The little bit of reading on the swap I did everyone is saying the stopping power is unmatched. It seems more boost can be made with the hydroboost than normal vacuum boost and being that I don't have a transbrake it was worth a shot. And it was a cheap mod so screw it
