BlackGMC build, suspension, fuel system, exhaust etc...
Old 07-15-2012, 09:36 PM
  #21
ak2007r6's Avatar
Damn.. this will be a fun build to follow. In for watching the exhaust setup
ak2007r6 is offline
Old 07-15-2012, 09:55 PM
  #22
Resident Retard
BlackGMC's Avatar
Yeah the exhaust is going to be rather unique, it is going to be dual 3inch, but the pipes are going to run under the transmission and the xpipe is going right under the crossmember. Below is the tranny crossmember i built when i built my 4l80. I designed it for this sole purpose. The exhaust pipes will exit before the tires for now. When the 4 link is done i want to run duals out the back like i have it now, exiting in the corners.
BlackGMC is offline
Old 07-15-2012, 09:59 PM
  #23
ak2007r6's Avatar
I need to learn how to weld. .... I need more garage space......
Do you have a pipe bender or just buying all the curves and welding it all together?
ak2007r6 is offline
Old 07-15-2012, 10:01 PM
  #24
ltr450ryder's Avatar
that crossmember is amazing!
ltr450ryder is offline
Old 07-15-2012, 10:08 PM
  #25
Resident Retard
BlackGMC's Avatar
Originally Posted by 1989k1500
Where did you get the lower shock mounts?
I made them Below are the first ones i made, they ended up being too long, soo i had to remake them but i did not take pictures but they look like the below.
This is the jig i made to help align and hold the upper and lower mounts. It worked like a champ!
Originally Posted by LS1TRUCKGUY
so what are you big power plans down the road????
either LS3 topend or FI... I have not decided...
I love welding. I am not the best but i am decent... The guy that was helping the last few days, i was teaching him to weld for the first time... He actually did pretty good for his first time...
I wish i had a bender... I usually buy 90* bend and cut them to the angle i want... Usually i cut all the 90*s into 45* and piece everything together that way...
BlackGMC is offline
Old 07-15-2012, 10:15 PM
  #26
ak2007r6's Avatar
ya it just seems like with a welder and some time and creativity the options are endless.
I have never touched a welder but a friend of mine was a welder on the USS Ronald Reagan for 5 years and just bought a welder for home so hoping I can learn one of these days. When I finally get my LT's and all that I will get a chance to learn and have him help me weld it all up.
What was your reason for doing true dual over a single??
ak2007r6 is offline
  #27
Resident Retard
BlackGMC's Avatar
Thanks man, i might be ditching it... I have a tubular crossmember that i might swap it out for...
BlackGMC is offline
Old 07-15-2012, 10:22 PM
  #28
Resident Retard
BlackGMC's Avatar
Also on a side note, I did not adjust anything on my tune and the trims were still +/- 3%.... I left the IFR table the same, because i did not hook up the vacuum reference... After i swap out the exhaust and need to retune it I will hook up the vacuum reference line and adjust the IFR table for return style. I thought that was worth noting.
BlackGMC is offline
Old 07-15-2012, 10:47 PM
  #29
Resident Retard
BlackGMC's Avatar
Learning to weld and owning a welder is great! Honestly i have no clue on what i would do if i did not have one... Metal is one of the easiest things to work with. I learned to weld working in an exhaust shop during college, and i also welded when i worked in a body shop... Actually this is my first time welding stuff this thick... 3/16 is the thickest i have tried to weld with this welder. It is a lincoln 175 (220 volt), it is not as nice as a miller but it works for me. Eventually a tig will be sitting next to it
About the dual 3inch, i dunno, just something different, plus i have all that room underneath, might as well use it right??
BlackGMC is offline
Old 07-15-2012, 11:45 PM
  #30
Custm2500's Rude Friend
1FastBrick's Avatar
Just wait till you go to weld the 4 link brackets on...
1FastBrick is offline
Quick Reply: BlackGMC build, suspension, fuel system, exhaust etc...
