'89 Chevy C1500 5.3 turbo build
#48
Thanks! Do you have a build thread as well?
#49
Nice build! Im boosting my 06 5.3 soon, if you don't mind sharing were did you get your oil line feed from and return line? Im thinking of setting my return line on the oil cap that's on the valve cover. I dunno if that'll work tho.
#50
I got a Trick Performance (one of our vendors on the right hand side of the page) turbo oil line kits. You wont be able to return your oil to the oil cap unless your turbo will sit higher than the cap because the oil return is gravity fed. Unless you buy a return pump, but I see that being entirely unnecessary. Im guessing the reason you wanted to do it this way is because you don't want to tap the oil pan, well an easier alternative would be to just tap the bottom of the front timing cover and put your return line there.
