6.0 Turbo build
Old 11-28-2013, 02:03 PM
I have a gauge for that
Atomic's Avatar
stock head bolts tend to break off in the block when you re use them.
Old 11-28-2013, 04:13 PM
GRRR65GTO's Avatar
Oh i thought he was talking about head studs or something aftermarket. Yeah i got all new gm bolts
Old 11-29-2013, 11:17 PM
GRRR65GTO's Avatar
I just mocked everything up today and I ended up shoving the radiator and condenser back like 2 inches and now I have plenty of room for the intercooler and trans cooler. Granted I did cut out the hood latch a frame and I still have to redo it
2013-11-29182647_zpsa05596ab.jpg?t=1385787470
2013-11-29182704_zpsd2f6438a.jpg?t=1385787486
New brackets for condenser to sit on
2013-11-29230011_zps5c27ae89.jpg?t=1385787506
Old 12-02-2013, 09:57 AM
Bama2door's Avatar
Yea not a fun time...
Old 12-02-2013, 07:02 PM
GRRR65GTO's Avatar
So the trucks running now. I started it at about 3 am this morning, slept for 3 hours and then drove it to school. The oil drain didnt exactly comeout how I had hoped...
There was less room than I thought between the A/C belt and the water pump cause thats where I was gonna run it, so instead I notched out some of the compressor bracket and got this. I have a bad feeling that its not a good enough gravity drain so I was hoping someone could tell me if it'll work or not.
2013-12-01214908_zps400bf4ea.jpg?t=1385952769
I took the oil cooler lines off and tapped the block, drilling from the back so there was no guessing whats on the other side of what im drilling into. I capped it for now since I dont have the turbo on yet
2013-12-01160428_zps84c5d8ce.jpg?t=1385952780
2013-12-01164357_zps7da2ce60.jpg?t=1385952796
Oh and I was smart and forgot to order a longer crank pulley bolt and of course no stores had one around me so I made one, well kinda, my dads a better welder so he welded it
2013-12-01214954_zps44b93bae.jpg?t=1385952735
2013-12-01215006_zps0808e52c.jpg?t=1385952713
Old 12-02-2013, 07:23 PM
GRRR65GTO's Avatar
Now that I found out about the bad reveiws of the smartfire injectors would these be a another injector that would work if they do turn out to be bad?
Siemens Deka V 80lb HR Fuel Injectors Fit EV1 Bosch Short Stubby Pico D5 840cc 8 | eBay
Old 12-03-2013, 09:21 PM
GRRR65GTO's Avatar
Im not asking for much just a few peoples opinions and input...
Old 12-03-2013, 09:50 PM
Atomic's Avatar
Deka 80s are fine injectors, very common. I think I saw a set in the classifieds for $300 or so...
Old 12-03-2013, 09:56 PM
GRRR65GTO's Avatar
Ok i think im gonna return the smartfire ones and just get deka ones. Which kind is the right kind or will both work? The short vs tall
http://pages.ebay.com/motors/link/?n...d=390684290068
Old 12-03-2013, 11:48 PM
kelsey_canard's Avatar
yea, good decision on ditching those smartfire injectors. I am running the siemens deka 80s. I'd go with the tall injectors, as it is cheaper to space the fuel rail up than it is to space the injectors up.
Quick Reply: 6.0 Turbo build
