2008 Sierra v6 to v8 swap almost complete...
Old 11-06-2016, 09:14 PM
Helomedic1171's Avatar
Default 2008 Sierra v6 to v8 swap almost complete...
I swapped a 2008 GMC Sierra RCSB 2wd V6, but I'm having one last issue. I used a 2008 5.3 truck harness, a 2008 E38 ECM from another 5.3 truck, and a frankenstein engine - gen IV shortblock with gen III heads and intake. it all went together surprisingly easily, and after completing the security re-learn, I'm left with 3 codes:
Crank re-learn not performed
Fuel pump module lost comm
Fuel pump ckt malfuntion
The crank re-learn I was totally expecting. the other two codes seem to come from the fact that the V8 trucks had a FPCM, but the V6 trucks did not. Can I just delete/disable the FPCM from the tune and use a more "traditional" method like a ground or reference voltage signal to activate the fuel pump relay? I really don't want to put an FPCM, pressure sensor, and associated wiring in this thing, plus get a dealer reset.
Any help is appreciated. in the mean time, if anyone has questions about the swap, feel free to ask or PM me.
Old 10-10-2019, 05:13 PM
Registered User
Nickie Montealegre Prado's Avatar
Hey man, i know this post is old but were you able to figure it out? Im having the same exact issue, same exact codes. Threw in a gen 4 motor with gen 3 heads just like you did but still having the same issues.
Old 03-11-2020, 03:07 PM
Registered User
CJ Whitt's Avatar
Anything on this i am running into the exact same problem would love to know the fix thanks in advance
juliof117
04-15-2018 08:50 PM
Revoroller
03-13-2017 10:01 AM
melition
03-14-2015 07:18 PM
Quick Reply: 2008 Sierra v6 to v8 swap almost complete...
