stand aloe tank pumps
Old 08-23-2016, 11:03 AM
06murder's Avatar
Default stand aloe tank pumps
What kind of pumps are y'all running in stand alone tanks for nitrous for c16? Would a flex fuel pump work?
Old 08-23-2016, 12:27 PM
I have a gauge for that
Atomic's Avatar
If you are talking about just providing enrichment fuel just about any pump will work. The good ol walbro255 would work fine.
Old 08-23-2016, 01:41 PM
06murder's Avatar
I had a walbro 255 in the tank but it got rusted. So i was think put a flex fuel one in and be done but i wasn't sure if c16 will miss it up or what. Because i have like 2 of them,lol work great, only reason i got them was because we had few truck come in the shop with rusted fuel pumps and broke fuel fittings so we replaced the whole the assembly
Old 08-23-2016, 01:57 PM
Atomic's Avatar
The actual fuel pump was rusting? That's interesting...
C16 will be fine with any gas pump.
Old 08-23-2016, 02:07 PM
06murder's Avatar
Yeah! You tell me it blew the fuse when turn the pump on to see of it worked still, when it blew fuse i took the pump out it was rusted so bad i just threw it away! I figure flex pump would work best, time will tell.
Old 08-23-2016, 02:11 PM
Atomic's Avatar
Its interesting because nothing submerged in gasoline will rust unless it has a ton of water in it.
Old 08-23-2016, 05:36 PM
Truck Sponsor
TrickTurbo's Avatar
Unless the pump didn't stay submerged.
What's the tank made out of?
Old 08-25-2016, 01:12 PM
06murder's Avatar
Plastic, i think its from y'all truth be told. Idk if it was the one y'all put in there or what. Doesn't matter just wondering if the flex pump be enough for 250-300 shot i doubt I'm going that high 250 tops just don't wannabe put stress. On the pump you know
Old 08-25-2016, 01:24 PM
Atomic's Avatar
If you plan to spray at the normal 10psi or so then a stock pump will be more than adequate.
Old 08-25-2016, 01:47 PM
06murder's Avatar
Damn that's all it need ten poundsof fuel.lol
Quick Reply: stand aloe tank pumps
