Nitrous trucks need a catch can.
Old 02-23-2017, 08:03 PM
Truck Sponsor
TrickTurbo's Avatar
Default Nitrous trucks need a catch can.
2016 5.3L. Engine has 15K on it.
This was after 3000 miles of highway driving, N/A truck.
Catch can installed in the pcv line.
This is what the Trick catch can caught.
The oil in the intake track will cause a nitrous engine to get into detenation easier.
Old 02-24-2017, 12:23 AM
Truck Sponsor
Atomic Performance's Avatar
20 years of LS/LT motors from GM and they still can't figure out how to not suck up oil
Nice job!
Old 03-09-2017, 12:44 PM
53bowtie's Avatar
As I understand it most DI engines have this problem and especially when you add boost to the mix. My wifes old Hyundai Veloster turbo 4cyl. would have 1/2-3/4 full catch can every oil change......
Old 03-09-2017, 09:19 PM
B_5point3's Avatar
Do you have more pics of the setup?
Did you only need 1 catch can? These trucks have 2 vacuum lines so I'm just trying to make sure 2 cans aren't needed.
Old 03-09-2017, 11:20 PM
Truck Sponsor
TrickTurbo's Avatar
You only need one.
You only put it in the pcv line.
Old 03-10-2017, 10:38 PM
B_5point3's Avatar
Originally Posted by TrickTurbo
You only need one.
Was thinking about the wrong lines.
Thanks for the reply though.
Old 03-18-2017, 09:54 PM
blackcash's Avatar
The problem on DI engines, is you have no fuel flowing past the intake valve so you get massive carbon build up on the valves from the PCV. Been a known issue with VW/Audi for the last 10 years.
