high miles + nitrous?
okay so i picked up a 2001 1500 extended cab with a 5.3L that has 246000 miles
i am a LT1 guy and this is my first LS motor. i know the last 100k on it has been very well maintained buy my lil brother. the motor has about 50psi oil pressure at idle then little over 60psi when at WOT. also it doesnt have the notorious piston slap on start up that i have heard other LS motors have.
i have sprayed my fair share of nitrous with my LT1 racecar but i dont know anything about this newer style motors.
it has a hypertech tuner on it but i can put the stock tune back in if i need to for better timing maps. but i am wanting to spray a 100 - 150 shot on it ... but like i have said i dont know anything about these motors. high mileage motors are looser generally and seem to do okay with spray but what do you guys say
LM7, ~250k, good oil pressure +a little spray ?
I'd say you'd certainly be fine speaying a healthy motor regardless of mileage. I sprayed mine with 150k on it. I'd recommend looking into the IAT relay timing retard trick which I covered in my build thread. This will auto pull timing only when nitrous is sprayed. certainly convenient.
As long as timing is in check and you spray a wet shot I see no reason to not spray.
Also look into a window switch, spray thru shifts will smoked your trans.
I have an entire nitrous setup, with custom wiring harness for sale in classifieds if you do go this route.
I've sprayed a 150 shot on my tuned 290k mile motor and plan on doing it again this weekend. I mix in some 110 octane just to be safe though since the timing is bumped up. Like said above though, if it's a healthy engine then get after it. Just be conscious of the octane you use and timing. Miles are relative and most of mine are easy highway miles.
Former Vendor
So to re-cap, as long as you are not burning oil then nitrous is a great add on!!
really slow truck
13
03-05-2002 08:57 PM
