GM ls computer... IAT vs ECT sensor trick
I have seen ppl using both IAC and ECT with relays and resistors to use the stock computer to pull timing and add fuel. I have looked in the tune and I see ways to pull timing and add fuel with with either sensor. So... what are the pro and cons of using one vs the other or even using both?
Thanks for helping the noob!
https://ls1tech.com/forums/nitrous-o...de-system.html
Here's a great writeup from the tech
The idea is you use a relay to tell the computer that it is seeing -40° Intake temps. It will then reference the table that changes timing based on iat and use whatever values you put into the table. For a 150, I'd recommend 4 to 6 degrees pulled. The relay is setup so it activates at the same time as your nitrous, so the normal driving conditions are unaffected, and you stay safe when spraying.
For what it's worth, I would highly encourage anyone running a SD tune to Not use this method to pull timing. It's far too risky. Some have successfully used this method, a few have not. Another method to pull timing with our PCMs is to activate the traction control to kick on and just set the amount of retard in your the TC table on your tune. I've thought about using the PCMs output with a relay in series to have the TC request signal function as an rpm window switch as well, since the tables for TC request is scaled in rpms on the x-axis.
Can anyone confirm if the TC retard method is reliable and works on any year PCM?
JFortner5
08-28-2016 06:33 PM
