Carbed 5.3, what cam would you reccomend? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 09-17-2012, 01:09 PM   #1
Default Carbed 5.3, what cam would you reccomend?
It's going in a 3100 pound nova, th350 3500 converter, 4.11 rear car. He wants it na right now but he is a nitrous junkie so getting a cam that would work well with a 150 shot or so would be a good idea. I found plenty of cams people are running in trucks but I don't know how much difference the weight will make. Any ideas? Oh, and he is just wanting to swap cam and springs if possible.
operatorfailure is offline   Reply With Quote
Old 09-17-2012, 02:18 PM   #2
TXsilverado's Avatar
LS1tech has a carb section that has alot of information. it really depends on which intake manifold he plans to run.
TXsilverado is online now   Reply With Quote
Old 09-17-2012, 02:48 PM   #3
Gotcha. I will check out over there. I have never been a carb guy so I don't know what differences it makes on cam choice. Usually responses over here are more on topic and helpful than ls1tech, lol.
Old 09-17-2012, 02:54 PM   #4
Quote:
very true. it's always easiest to just pay someone to come up with a custom spec. Howards cam has alot of off the shelf LS camshafts that just happen to look like good grinds for a single plane intake. what intake is he running?
Old 09-17-2012, 02:58 PM   #5
He hasn't bought one yet, i just convinced him to go ls over a sbc.
Old 09-17-2012, 06:28 PM   #6
He said he is planning on buying the victor intake. I asked if it was the super victor or victor Jr, or what. He didn't know, just said a single plane.
Old 09-17-2012, 10:20 PM   #7
vic jr for a 5.3. what does he plan to do with the truck?
Old 09-18-2012, 05:25 AM   #8
It's a nova, but street/strip kinda car. More strip than anything but still wants to be able to take it out and cruise when he wants.
Old 11-05-2012, 07:02 PM   #9
Tell him to call Geoff at EPS and get him to spec a custom ground cam. I know a lot of guys around here use him.
Lazered98 is offline   Reply With Quote
Old 11-06-2012, 06:20 AM   #10
low2001gmc's Avatar
carbed ls combos tend to respond better to cams with an lsa in the 110 range. since he will be running a 3500 stall and 4.11s with a th350, i would say a cam in the 220-224 range would be best. as for swapping just cam and springs, aftermarket hardened pushrods are almost mandatory and best. good luck with the project...should be fun in a 3100 lb nova, rob
low2001gmc is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Gen IV 5.3 for boost JordanH GM Engine & Exhaust Performance 9 08-08-2015 08:59 PM
cam help elpyro89 GM Engine & Exhaust Performance 1 07-28-2015 06:51 PM
another cam thread steves86ta GM Engine & Exhaust Performance 5 07-28-2015 11:21 AM
Custom ground 4.8/5.3 cam 06 4.8 GM Parts Classifieds 2 07-15-2015 08:17 PM
Tags
53, big, biggest, cam, carb, carbed, company, howards, intake, ls, ls1tech, missouri, motor, nitrous, plane, powered, single, springfield, vbulletin
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
